Home > Maintenance & Modifications > Lamp Guards |
sjuggins Member Since: 18 Jun 2012 Location: Bedfordshire Posts: 25 |
Anybody?? |
Thu Jun 28 2012 11:47am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Do these by any change screw into the existing screw holes in the lights, ie, if you take them off, can you just stick in the original screws which may be a shorter length Obviously I appreciate you may not have these ON THE WAY: BMW F21 M140i
Thu Jun 28 2012 12:12pm |
I haven't removed the headlight to check properly but it appears the guard screws into the face of the grille surround. From looking at the installation instructions it would seem holes are required to be drilled before fitting the guards |
Thu Jun 28 2012 12:55pm |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
Surely that will invalidate any corrosion warranty Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Thu Jun 28 2012 1:00pm |
Isn't the grille surround plastic? |
Thu Jun 28 2012 1:09pm |
So to answer my own question, yes the grille is plastic. So I've removed the lamp guards and you need to drill the bodywork in some places (rear lights) which is unseen after removal. When removing the front guards there are holes left in the grill (approx 5mm each). One word of caution to any of you thinking of fitting the guards. Where one of the front brackets (nearside) had been fitted it has rubbed against the paintwork over the years to the point there is now two small patches (10mm x 2mm) of corrosion I'm assuming that as the guards were fitted after the factory build the corrosion guarantee is of no use? |
Fri Jun 29 2012 1:49pm |
If its fitted by the factory or the dealer within a certain period after purchase, it carries the full warranty
Sat Jun 30 2012 10:00am |
