Home > General > What happens if?????
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
To begin with I do not suggest that anyone tries this on their own car!
Driving along with my 11 year old daughter yesterday when out of the blue she asks "Dad, what happens if you press the start button while you are driving?" Confused
Later in the day I had to pop into the dealership where I purchased my RRS, so I asked the same question as my daughter. Answer was "We don't know!"
So any tech heads out there who know the answer?????
Jim
Post #346981 Fri Jun 15 2012 8:19am
I would assume there is an override that says 'you can't do that' above a certain speed. Confused
Pop out and try it Jim and report back Whistle Laughing ON THE WAY: BMW F21 M140i
Post #346986 Fri Jun 15 2012 8:36am
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
is it just not like switching off with the key (which is terrifying!!) engine cuts out, power steering fails and the steering lock locks!!, but then as it is an electrical gadget there will be some sort of backup!!
cheers
dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #346989 Fri Jun 15 2012 8:43am
jim4244
BC...I'll pop out right now, wind the old girl up to 110 mph on the dual carriageway and give it a shot!
Rolling with laughter Rolling with laughter Rolling with laughter
If it all goes horribly wrong I'll just tell the insurance company / Land Rover warranty "Oh, its OK, Beancounter said it would be fine!"
Jim
Post #346990 Fri Jun 15 2012 8:46am
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
its doesn't work, won't stop the engine from the stop button unless its in park
try slamming it into park whilst doing 110 Laughing Laughing i bet you won't even make it to the stop button
Post #346997 Fri Jun 15 2012 9:02am
^^^ Rolling with laughter
Been nice knowing you Jim.
Agree Dave, but I do wonder if there is some override Confused
Funny, my last 4 cars have all had a stop/start button and I've never thought about this. ON THE WAY: BMW F21 M140i
Post #346998 Fri Jun 15 2012 9:02am
x5pea
I always try that sorta stuff out, who's mastered the art of the electronic handbrake whilst moving Whistle
Post #347000 Fri Jun 15 2012 9:04am
I like you inquisitiveness pea Laughing If there's a button, press it. Thumbs Up
My ability to do handbrake turns has been severely hampered since the invention of EPB. Rolling with laughter ON THE WAY: BMW F21 M140i
Post #347005 Fri Jun 15 2012 9:07am
I have tried the EPB whilst moving. It works. It uses the ABS system to work all the brakes as I understand it. If you had a failure of the hydraulic system then the EPB could also be used to stop you but it would be a bit slower, obviously.
I think there's something in the manual about using the EPB to slow down. 2012 SDV6 - it's missing a couple of cylinders
Post #347019 Fri Jun 15 2012 9:48am
MAW
Not sure that is true X5.... I often pull on to the drive and hit start and at rest the gear selector automatically finds park before shutting down
Post #347021 Fri Jun 15 2012 9:55am
On the 8 speed box, when you come to a halt with it still in D, then press the stop/start button, the dial goes into P as it shuts down, did this by mistake one day Embarassed I wouldn't like to try it on the move though. Shocked
Post #347024 Fri Jun 15 2012 10:30am
x5pea
Never thought about the post 2012 MY , suppose that would make sense as the select is electronic but again it won't stop the engine until the car has stopped moving i assume..... pre 2012 the select is manual as I'm sure your aware.
Post #347036 Fri Jun 15 2012 11:45am
Chicken George
United Kingdom 2009 Range Rover Sport TDV6 S Santorini Black
on a freelander2 the engine dies if you press (and hold) the stop start. steerig lock stays on unless you remove the fob from the dock.
Post #347064 Fri Jun 15 2012 3:35pm
