Home > General > PAINT TOUCH-UP - need advice |
All you need to know here if you are brave enough
Fri Jun 08 2012 4:22pm |
JimKim Member Since: 09 Jun 2012 Location: Didcot Posts: 90 |
Use a cotton bud stick. Cut the stick in half on the angle to make a point and use that to fill the chip rather than brushing then use the bud end to remove any you spill. We mix the paint with ronseal quick drying wood varnish to act as lacquer when we do it ( I work for Revive mobile body shop ). |
Sat Jun 09 2012 4:07pm |
