Home > General > PAINT TOUCH-UP - need advice
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
My 2006 needs a few stone chips touched-up. I've got the Gold Mayo paint stick and I've tried to 'spot out' a couple of chip marks and made a right muck up of the job!! I would be grateful for advice on the best way to approach the job. Andrew Andrew Kennedy
Post #346259 Fri Jun 08 2012 4:15pm
All you need to know here if you are brave enough Thumbs Up
http://www.detailingworld.co.uk/forum/showthread.php?t=217520
Post #346260 Fri Jun 08 2012 4:22pm
JimKim
Use a cotton bud stick. Cut the stick in half on the angle to make a point and use that to fill the chip rather than brushing then use the bud end to remove any you spill. We mix the paint with ronseal quick drying wood varnish to act as lacquer when we do it ( I work for Revive mobile body shop ).
Post #346353 Sat Jun 09 2012 4:07pm
