![]() | Home > Technical > Rear ride height issue |
Gibbsy1966 Member Since: 25 Apr 2012 Location: Derbyshire Posts: 73 ![]() ![]() ![]() |
Hi Mike
Mike_C Member Since: 19 Mar 2012 Location: Bucks Posts: 184 ![]() ![]() ![]() |
Oh good! I think the compressor is fine, it doesn't run too long and the suspension rises and lowers quickly. Hopefully just requires a ride height reset?![/list] - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE)
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
mine has done this a few times i also have a gravel driveway ive noticed when i dont park it on its usuall spot on the driveway it extends it to normal height i do have deep gravel on the drive so this might be the cause |
if you have the 4x4 info screen, you should be able to see which wheel it is that thinks it's at a different height. Almost always that ride height sensor failing or someone has recalibrated it completely wrongly. |
