Home > Technical > Rear ride height issue
Mike_C
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Tangiers Orange
Bit of an odd one, the car seems to keep putting the rear of the car in 'extended' mode when it should be in normal. The front is the corrent normal height, so the whole car tips forward.
Doesn't seem to do it all the time, but a message on the info display mentioned something about it trying to clear an obstacle.
Not sure how it recognises obstacles but seems odd. Does parking it on a gravel drive have any effect on this?
If you try to drop it to Access height it will try to go back up because of the rear end, so then you have to 'lock' it in Access height, which is a ballache too.
Can I reset the suspension ride heights or is this a diagnostics job?
Cheers! - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE)
- BMW 330Ci M-Sport coupe
- Suzuki GSX-R750 K6 'Stealth' - trackdays and high speed tourer
Post #345939 Tue Jun 05 2012 7:10pm
Gibbsy1966
England 2011 Range Rover Sport 3.0 TDV6 HSE Lux Sumatra Black
Hi Mike
Seem to be having very similAr challenges with the RRS!!!
I ended up having a height sensor and the air compressor replaced BMW 530D 2011 still here
Porsche Boxster S gone - RRS Supercharged bought to transport 2 Tibetan Terriers!!
Post #345942 Tue Jun 05 2012 7:28pm
Mike_C
Oh good! I think the compressor is fine, it doesn't run too long and the suspension rises and lowers quickly. Hopefully just requires a ride height reset?![/list] - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE)
Post #345973 Tue Jun 05 2012 9:33pm
baxc
mine has done this a few times i also have a gravel driveway ive noticed when i dont park it on its usuall spot on the driveway it extends it to normal height i do have deep gravel on the drive so this might be the cause Thumbs Up
Post #346027 Wed Jun 06 2012 3:45pm
Bodsy
Site Sponsor
if you have the 4x4 info screen, you should be able to see which wheel it is that thinks it's at a different height. Almost always that ride height sensor failing or someone has recalibrated it completely wrongly. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #346319 Sat Jun 09 2012 10:51am
