Home > In Car Electronics > mp3 /2012 rrs
skywriter
mp3 /2012 rrs
help needed my mp3 will not play downloaded tracks in my2012 rrs but it worked fine in my 2010 rrs dealer says it does not recognise removable media does anybody have a solution for this or is there a way to download stuff a different way thanks
Post #345347 Wed May 30 2012 6:17pm
WolfgangK
Germany 2012 Range Rover Sport SDV6 HSE Nara Bronze
hello , how do you connect your mp3 to the radio ? USB, AUX , or is it a cd ?
regards
WolfgangK
Post #345350 Wed May 30 2012 6:28pm
rstebbings
I either plug my iPhone in to the ipod socket (under arm rest) then select the tracks from there OR I connect it via bluetooth - not had an issue
I have thou not been able to rename tracks that I have copied form a CD to the HD
Post #345354 Wed May 30 2012 7:08pm
Lookers Park Royal
Rather than burn the Mp3's to disc, instead put them on a USB and plug into the socket in the cubby lid.
James Thumbs Up
Post #345363 Wed May 30 2012 7:29pm
skywriter
hi again thanks for the replies in answer to the first, i use a cable from the usb port under the cubby lid
Post #345391 Wed May 30 2012 9:49pm
rstebbings
You got another MP3 player to try ? might not be compatable
Post #345393 Wed May 30 2012 10:27pm
mlines
I had problems like this with both an Ipod and USB stick when plugged into the USB/Ipod port.
Only a few tracks on the USB were recognised and they skipped or stuck
The Ipod locked up after each track.
This was after I had just got the 2012 car.
I took the USB stick, reformated it on my PC and download a new, clean set of music (ie. no deletions or data files on the USB stick.
I factory reset the Ipod and reloaded it.
After doing this both were fne. I suspect that the RRS could not cope with the deterious of normal operations that had built up on both devices and needed a clean file system
Martin 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #345444 Thu May 31 2012 1:02pm
skywriter
what do you mean by reformating the stick?
Post #345460 Thu May 31 2012 4:08pm
rstebbings
IT 101
http://www.ehow.com/how_4810471_usb-memory...evice.html
Post #345461 Thu May 31 2012 4:12pm
