Home > In Car Electronics > removing standard stereo |
smurf Member Since: 16 Aug 2010 Location: cheshire Posts: 81 |
anyone taken out the standard stereo and fitted another double din unit with the seperate surround.if so any pics pls and was it easy to do,just wanted something that is more compatable with my iphone. |
Mon May 28 2012 8:47am |
Gibbsy1966 Member Since: 25 Apr 2012 Location: Derbyshire Posts: 73 |
If it's a 6cd changer audio head and you do remove it I'll buy it off you BMW 530D 2011 still here
Mon May 28 2012 5:16pm |
STREAKY
Tue May 29 2012 11:01am |
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 |
Smurf, sounds like you need an updated BT module rather than a head unit. I am making this statement on the assumption that your car is bluetooth enabled (red and green buttons on the steering wheel), if this is correct then PM member Wiggs who can sort you out with an updated module. Then you can see your address book etc on the screen on the stereo.
Tue May 29 2012 3:07pm |
Streaky Member Since: 31 May 2010 Location: Dubai Posts: 259 |
Smurf...Simon's hit the nail right on the head. My 2008 model has Blue Tooth and displays caller I/D from the contacts list when I have incoming or outgoing calls. Ra-Ro Sport Super Dooper Charged.
Wed May 30 2012 7:46am |
Cheers gents |
Thu May 31 2012 5:17am |
Firstly, thanks for the advice about the BT upgrade (ordered a module from Wiggs)
Thu May 31 2012 6:12am |
Thu May 31 2012 6:19pm |
