![]() | Home > In Car Electronics > Upgraded subwoofer and amps |
Strathearn Engineering Member Since: 23 Mar 2012 Location: Aberuthven PH3 1HE Posts: 65 ![]() ![]() |
An upgrade from what? Assuming you have an HSE, which no doubt comes with the H/K setup, I, personally, have found this setup to be perfectly good.
bermyandy Member Since: 09 Sep 2007 Location: London Posts: 336 ![]() ![]() |
I opted for something similar to this
Streaky Member Since: 31 May 2010 Location: Dubai Posts: 259 ![]() ![]() ![]() |
Can you use the existing sub woofer amp on a RRS to power an aftermarket sub cabinet? Whats the power output of the amp, where is it and what connections does it use for outputs/signals etc? Ra-Ro Sport Super Dooper Charged.
I think if you are going to the effort of fitting an aftermarket sub, you should use a proper amp - I would be surprised if the existing one would do it justice |
My point exactly. Whats the power output of the standard sub and what are the connection types?
Ballsy Member Since: 19 Jan 2012 Location: Fife Posts: 160 ![]() |
Not sure what ratings the speakers or amp is but I doubt it will power your 2 12's. Will be very loud with the correct amp/s
firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461 ![]() ![]() ![]() |
wow what you trying to do, i turn mine up full and my ears bleed.......... |
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 ![]() ![]() ![]() |
A somewhat related post and just a piece of advice, if you are changing your current car audio, do it with Pioneer, if you can afford of course. No other company can match the quality of the music pioneer devices produce. It is a matter of opinion, somewhat, but I have had different brands installed in my previous cars. And pioneer was th best. And I am talking serious music here, proper 300 watts front and rear speakers, 4 channel amp, min 3000 watts sub and mono amp for the sub. Etc etc. lol I used to think I ruled the world driving in the city centre |
Pioneer head units are very good, the speaker range is average at best. You can get a lot better quality from other manufacturers for the same or less money. |
