Home > Faults & Fixes > RRS 3.0 blowing blue smoke...tons of it
gmilner
Australia
Has anybody in the UK had this problem? My 2010 RRS 3.0 started blowing clouds of traffic-obscuring blue (oil) smoke under sharp acceleration shortly after being serviced a couple of months ago.
It would only happen intermittently, ie I'd get it to blow a big cloud of smoke then try it again and nothing would happen.
The local LR dealer replaced the secondary turbo under warranty, which didn't fix the problem. Then last week they replaced the replacement turbo with another (modified) turbo, said that would fix the problem, and it didn't.
So today they're telling me it's because at the second turbo replacement, a one-way valve and a dump valve should have been replaced at the same time, and weren't. So now it's booked in again for its (almost) weekly warranty work as soon as the parts arrive.
They replaced secondary turbos on a dozen 3.0 Discos and RRSs at this dealer alone, so it's not exactly an uncommon problem. Anybody else heard of this issue? Greg Milner
Perth, Western Australia
2010 RRS 3.0. For towing boats and bashing corrugated outback roads.
2007 Audi TT Quattro (wife's shopping cart. Time to go)
2013 Polo GTI (wife's new shopping cart.)
2007 Holden Caprice V8 ('cos it's not worth selling it)
Post #343521 Mon May 14 2012 7:17am
Bob.
There is a Technical Bulletin titled "LTB00358v5 - Secondary Turbo Oil Leak Excessive Exhaust Smoke" on TOPIx.
Sounds a good candidate and it's on Version 5 so they have had a number of goes at solving the problem so maybe the garage did the work to an earlier version and have since seen a later one.
Post #343614 Mon May 14 2012 10:31pm
gmilner
Australia
Okay thanks Bob I'll take a look at it. Greg Milner
Post #343615 Mon May 14 2012 10:41pm
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Re: RRS 3.0 blowing blue smoke...tons of it
Since i`m no from the UK, hope that i`m still allowed to answer your question Wink
Had the same thing after the anual service and a repair on the engine (not the turbo).
LR had to remove the plastic turbo pipe to make the repair.
During the reinstal they obviously damaged it, so when i picked it up, it blew the famous tons of blue smoke.
After replacing the cracked turbo pipe (of course not under guaranty, since they just denied damaging it) there was no more smoke.
Hope this helps! Thumbs Up SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #343734 Tue May 15 2012 6:11pm
gmilner
Australia
Yep, sounds exactly what's happened in my case. Thanks for the confirmation:-) Greg Milner
Post #343766 Wed May 16 2012 3:21am
Ielk2001
I have exactly the same on a 4.4 full fat range rover which only started after the turbos were warranty replaced. What is it exactly that's causing the blue smoke in your cases? Mine only seems to do it after a long run and only when I slow back down eh in traffic. Only lasts about 10mins or so and then is fine again with no smoke until the next time.
Post #603528 Fri Aug 21 2020 7:13am
DrRob
Ielk2001 - best go over to www.fullfatrr.com for your issue as the 4.4 is a totally different engine to the 3.0 RRS motor.
What you describe is well documented over there Thumbs Up
How often do you open the car up above 2500rpm? If you don't then oil is building up in the secondary turbo. There is a cure called the turbo drain mod. Not many places will do it as it's a totally different procedure on the 4.4. It involves a lot more work and drilling into the block/sump for a thread.
https://www.fullfatrr.com/gallery/albums/u...20Smke.pdf
Alternatively, give it some beans every time you drive it (when engine is warm). That way it won't accumulate over time.
See you over on the other forum Thumbs Up Visitor from fullfatrr.com
Post #603529 Fri Aug 21 2020 8:04am
Ielk2001
Thanks, will check there!
Post #603531 Fri Aug 21 2020 8:11am
DrRob
Best place for 4.4. advice.
Also check all your intercooler hoses.
Where in West Sussex are you? I'm in that area too Visitor from fullfatrr.com
Post #603533 Fri Aug 21 2020 8:13am
Ielk2001
Down in Worthing....cedar garage are awesome for RR repairs and servicing....
Post #603534 Fri Aug 21 2020 8:22am
DrRob
Yes, heard good reviews about them. What's their diagnosis??? Visitor from fullfatrr.com
Post #603535 Fri Aug 21 2020 8:36am
Ielk2001
It's going in next week so will let you know!
Post #603536 Fri Aug 21 2020 8:42am
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Does it happen over 2800rpm? Mine was the same and was fixed by the secondary turbo oil drain mod. Cost me £330 at the local indy. L494 3.0L SDV6 Autobiography in Chile Red (Current)
L320 3.0L SDV6 Autobiography in Baltic Blue (RIP 29/03/2021 insurance total loss)
Post #603543 Fri Aug 21 2020 10:21am
Ielk2001
Mine is the same although mine (full fat RR 4.4) only started after both turbos were replaced. Only intermittent too and I'm in UK. Will let you all know once fixed what was wrong but any ideas welcome as garage have already indicated if will be difficult if nothing obvious and not doing it when it goes in. So far I'm unable to reliably replicate the smoke.
Post #603547 Fri Aug 21 2020 11:07am
