Home > Technical > One corner of the car is lower than the rest. Offside rear. |
Does it drive level? RRS gone
Thu May 03 2012 11:10am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
As daft as it may sound could be another sensor causing it LRA logged on to one of my RRS's to look at which corner was faulty when I had the magic carpet experience.... |
Thu May 03 2012 12:24pm |
PM answered Jon
Thu May 03 2012 12:26pm |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
4x4 info will tel l you if there is an issue with one of the sensors , could just nee recalibartaed mate, get it into a dealer or specialist |
Thu May 03 2012 1:54pm |
jundrill Member Since: 18 May 2011 Location: Epping Posts: 64 |
It drives level. I checked the 4x4 info screen and the back offside where the issue is reports fine, no flashing red light etc but oddly when the suspension is set in the lower mode the front offside flashes red so maybe that's causing it somehow.
Fri May 04 2012 7:53am |
sounds like calibration mate, is the line green when in normal running height & off road mode? |
Fri May 04 2012 7:54am |
Yes, all fine when its in normal or high mode per se, the red light only flashes on the front offside when it's in the lower suspension mode and the rear only drips when its parked, and only sometimes. Odd. Getting it looked at again today. |
Fri May 04 2012 9:11am |
I've just got off the phone to Brown Church. They've tried everything and the car doesn't sink on the offside rear like it has been with me from time to time. They disconnected the battery and all four corners stayed the same height, they connected the Auto Logic and nothing came up, they checked to make sure the spring wasn't leaking, all came back ok..... Really odd |
Fri May 04 2012 9:17am |
pratty Member Since: 04 Mar 2012 Location: Hants Posts: 3 |
Hi
Fri May 04 2012 11:04am |
What senor did you have changed and what would a new compressor do?
Tue May 08 2012 2:32pm |
The sensor was the frount drivers side, car was down at the back driver side. Put the car in to Guy Salmon and they said it needed a new compressor as per diagnos as well as new sensor. I dont know the exact problem with the compressor. |
Tue May 08 2012 5:26pm |
