Home > Maintenance & Modifications > RRS TDV8 2009 Diesal filter problem- HELP needed |
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 |
I wonder if the filter drain valve is loose, might be worth checking first to see if the leak is from that. |
Sat Apr 28 2012 8:39pm |
JimboTD5 Member Since: 29 Jan 2010 Location: Hertfordshire Posts: 113 |
I did mine last week (TDV6) not sure if its the same on the V8 but its a very easy job, just remove the gearbox plastic shield (6 bolts) then remove the 3 bolts holding the fuel filter shield, drain the filter, unplug the water sensor wire then turn the filter anti-clockwise and remove.
Sat Apr 28 2012 8:46pm |
popple81 Member Since: 09 Apr 2012 Location: leicester Posts: 4 |
Thanks for that.
Sun Apr 29 2012 6:04pm |
