Home > Maintenance & Modifications > RRS TDV8 2009 Diesal filter problem- HELP needed
popple81
How easy is it to change the diesal filter. Mine appears to have a leak,
Has anyone done this themselves or does it need taking to a garage. Also any idea on the cost??
Any advice will help
Thanks wanted range rover sport tdv8 black
Post #341702 Sat Apr 28 2012 6:26pm
Bob.
I wonder if the filter drain valve is loose, might be worth checking first to see if the leak is from that.
Post #341707 Sat Apr 28 2012 8:39pm
JimboTD5
England 2008 Range Rover Sport TDV6 S Buckingham Blue
I did mine last week (TDV6) not sure if its the same on the V8 but its a very easy job, just remove the gearbox plastic shield (6 bolts) then remove the 3 bolts holding the fuel filter shield, drain the filter, unplug the water sensor wire then turn the filter anti-clockwise and remove.
Cant rember the cost of the filter but I think it was about £10.
I hope this helps.
Jim
Post #341708 Sat Apr 28 2012 8:46pm
popple81
Thanks for that.
Yes it is from the filter drain plug but have tried to tighten it and still leaking. wanted range rover sport tdv8 black
Post #341769 Sun Apr 29 2012 6:04pm
