Home > General > My rrs 2011 has problems at service |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 |
If its only one year old (2011) then yes, it should be fully covered under the warranty.
Mon Apr 23 2012 7:59pm |
RRS Craig Member Since: 14 Jun 2011 Location: Britain Posts: 139 |
Yes has manufacturers warranty for 3 years I believe. This is my second rrs never had this kind of problem, it seems slow to change up from 1st to 2nd? Any thoughts. RRS |
Mon Apr 23 2012 8:04pm |
Are you using drive when this happens or using the flappy paddles |
Mon Apr 23 2012 8:08pm |
That would be drive it must be the 2012 or supercharged with paddles....I presume? RRS |
Mon Apr 23 2012 8:09pm |
Flappies have been an option from 2009 onwards but became standard from the 2012 model, if its in drive and you are setting off from standstill then you motor is setting off in 2nd gear, they all do, thats why you think its slow selecting the next gear, its actually changing up to 3rd not 2nd due to the torque of these diesel engines. This might go some way to explaining your problem. |
Mon Apr 23 2012 8:17pm |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
rrs sc does not have flappy paddles, but it does have a grear stick rather than the dial. (i personally dont like the dial and paddles) I checked in the dealers last week. The sc does not come with the 8 speed box. is yours diesel or petrol sc?
Mon Apr 23 2012 8:21pm |
Thanks Ady sounds like you know what your talking about. The dealer also tested it after the software downloaded and said its not right it's as if it's stuck in 1st and will not go into 2nd until revs ars higher. It wasn't behaving like this when it was new, ie 6mths ago? RRS |
Mon Apr 23 2012 8:22pm |
Craig, you could try changing your gear in command shift see if it changes gear quicker and as it should What also could be happening Craig, the gearbox learns your driving style, this might be the case if you have been taking it steady for the first 6 months, it might just need to learn a new style of driving but teach it through the command shift for a while. ie setting off in 1st everytime. |
Mon Apr 23 2012 8:24pm |
Ady I you referring to pushing it into sport with the gear stick to the left, is this command shift? I have been driving short distances of late and I never drive it like I would a supercharged....more like driving miss daisy! Strange they kept it in.
Mon Apr 23 2012 8:37pm |
Its a diesel shepp RRS |
Mon Apr 23 2012 8:39pm |
Yes craig, slip it into sport mode it will show "S" on your dash, push it forward and it will select 1 then when you pull it back it will select 2 and so on to drop down a gear push it forward, it tells you what gear you are in on the dash, drive it around like this for a while giving it a few beans and it should get better when in drive, and stop driving it like mrs daisy give it some stick now and again when its warmed up and blow them cobwebs off it. More Pics of my motor are in my gallery |
Mon Apr 23 2012 8:47pm |
Many thanks Ady sound advice especially when I wasn't aware of your points. Cheers.
Mon Apr 23 2012 8:54pm |
Ady are your exhaust pipes all one or tips? The whole car is 10/10 RRS |
Mon Apr 23 2012 8:58pm |
Thanks craig Its not an A/B but it has got the A/B kit on from factory, the only difference in the kit from the full A/B kit is the front and side grills. The exhausts are A/B tips again factory to match the rear bumper |
Mon Apr 23 2012 9:09pm |
