Home > Faults & Fixes > Steering - slight drift to thee left.
Hugh Haddow
Scotland 2013 Range Rover Sport 3.0 TDV6 HSE Bali Blue
New 2012 model TRDV6 3.0 just 1600 ish miles. It seems to drift to the left if steering released. Checked tyre pressures, side wind and camber of the road but it still seems to be there irrespective of speed. Previous 2.7 was very stable steering wise.
Is it my immagination?
comments welcome.
Post #339698 Thu Apr 12 2012 10:21pm
It's new; take it back and ask for a full geometry check. And if they say "it's ok", take the spanner monkey out with you and scare him by letting it drift toward a tree in the verge... 2012 SDV6 - it's missing a couple of cylinders
Post #339701 Thu Apr 12 2012 10:41pm
Apparently a common issue Hugh with most RRS's leaving the factory with some sort of issue, some barely noticeable, some more significant.
Mine pulls the the right slightly and has got progressively worse recently (now done just under 4,000 miles). You spurred me to make a call this morning and I'm taking mine to a specialist place with 'Hunter' alignment equipment in the next week. Only costs £60 for a full front and rear adjustment and you get a printout before they commence work to show the adjustment necessary.
Was chatting to the guy on the phone and so far he has done over 15 MY12 RRS's this year already Shocked
Yes, I could take it back to the dealer, but I'd rather it done by guys who do it 'day in, day out'. Also the alignment place is a lot closer than the dealer I'd trust to do it. Laughing
Either take it back to the dealer, or get someone with decent alignment equipment to take a look, the sooner the better Thumbs Up ON THE WAY: BMW F21 M140i
Post #339713 Fri Apr 13 2012 7:50am
Mine is going in tomorrow, my steering wheel was off centre only very slightly but enough to annoy me, so i took it in the other day for them to check it, they tried to adjust it but to no avail, it isn't pulling to either side like yours, its just off centre Mr. Green so its going in for full geometry check, they said it will take 3 hours ish, i'm not fussed though, my dealer is only 10 minutes away and i'm getting another sport for the day. Thumbs Up
Post #339717 Fri Apr 13 2012 8:03am
Similar issue to be honest Ady, mine drives towards the right when the steering is held straight.
Seems the guys on the line are a little slap dash when adding the steering wheels Rolling Eyes ON THE WAY: BMW F21 M140i
Post #339719 Fri Apr 13 2012 8:45am
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
I've just got back to the UK and have driven into town for my usual £7.50 haircut. Whilst driving along the country lanes I notced that the steering wheel is out by a couple of mm to the righthand down position.
Have just checked the tyre pressures and found them to be bang on. I only have 1400 on the clock and the car has not been off road or been kerbed.
I know that it doesn't sound like much but I'm sure that the streering wheel should be dead center on a new car?
Jim
Post #339725 Fri Apr 13 2012 10:12am
Sounds like your another member of the 'my steering wheel's been put on wonky' gang Jim Laughing Thumbs Up
Sounds like a return trip to your dealer Wink ON THE WAY: BMW F21 M140i
Post #339727 Fri Apr 13 2012 10:35am
jim4244
How the Censored can this be the case on a £50K car Shocked
Jim
Post #339730 Fri Apr 13 2012 11:11am
I wonder if this will get reported back to the factory or is it a case of the guy putting the steering wheels on has a drink problem Laughing its not a case of just taking the steering wheel off and moving it around a few splines like in the olden days they have to adjust it on the steering rack Confused And if there isn't enough tolerance on that then a full 4 wheel alignment is required. Shocked
Post #339731 Fri Apr 13 2012 11:12am
Is pretty shocking, I agree Jim. Mad
As I say, guy at my local wheel alignment place said that pretty much every RRS, be they old or new, had some sort of alignment issue. Rolling Eyes
From what I've seen in LR's ability to respond to customer feedback/problems, I guess that the MY20 versions will be bang on Ady Rolling with laughter ON THE WAY: BMW F21 M140i
Post #339733 Fri Apr 13 2012 11:20am
jim4244
Do you think that anyone at Land Rover ever monitors the various threads around on the internet with regards to QC issues???
Jim
Post #339735 Fri Apr 13 2012 11:24am
That'd be a full time job for someone Rolling with laughter Whistle ON THE WAY: BMW F21 M140i
Post #339736 Fri Apr 13 2012 11:28am
I wonder if this issue is related to the air suspension on the RRS. The suspension has a tolerance such that even if the car is nominally sat level, each wheel can effectively have a different height relative to the body. As the geometry changes with chaning ride heights, in effect one could have a vehicle with different geometries on each corner. Drive slowly across uneven ground keeping the wheel straight and you can feel the wheels pulling left and right as the front wheels take up different ride heights (and thus camber settings etc.).
So if they set up the vehicle at the factory and each corner is near the limit of the allowed tolerance, it won't get picked up as a QA issue (because it's in tolerance) but might have an effect on the wheel alignment.
Just a thought. 2012 SDV6 - it's missing a couple of cylinders
Post #339775 Fri Apr 13 2012 3:37pm
Makes sense RRSTDV8, but you would have thought that they carry out the check with all corners set to zero, ie no air in them (must be easy to do at the factory Confused )
Failing that they should check them with all 4 wheels on a 'straight' piece of road. I'm fairly sure if Johnny QA man had test driven mine he would have noticed the desire for my car to drive around a right hand bend, even on the straight Rolling with laughter ON THE WAY: BMW F21 M140i
Post #339776 Fri Apr 13 2012 3:51pm
Hugh Haddow
This is begining to look like another Land Rover 'feature'.
Mine is in on Monday for a check. I'll advise how it goes.
In the mean time thanks for the chat.
Post #339879 Sat Apr 14 2012 2:47pm
