![]() | Home > Faults & Fixes > Steering - slight drift to thee left. |
Hugh Haddow Member Since: 03 Jul 2009 Location: Prestwick Posts: 202 ![]() ![]() ![]() |
New 2012 model TRDV6 3.0 just 1600 ish miles. It seems to drift to the left if steering released. Checked tyre pressures, side wind and camber of the road but it still seems to be there irrespective of speed. Previous 2.7 was very stable steering wise.
Apparently a common issue Hugh with most RRS's leaving the factory with some sort of issue, some barely noticeable, some more significant.
Mine is going in tomorrow, my steering wheel was off centre only very slightly but enough to annoy me, so i took it in the other day for them to check it, they tried to adjust it but to no avail, it isn't pulling to either side like yours, its just off centre |
Similar issue to be honest Ady, mine drives towards the right when the steering is held straight.
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
I've just got back to the UK and have driven into town for my usual £7.50 haircut. Whilst driving along the country lanes I notced that the steering wheel is out by a couple of mm to the righthand down position.
Sounds like your another member of the 'my steering wheel's been put on wonky' gang Jim |
How the |
I wonder if this will get reported back to the factory or is it a case of the guy putting the steering wheels on has a drink problem |
Is pretty shocking, I agree Jim. |
Do you think that anyone at Land Rover ever monitors the various threads around on the internet with regards to QC issues???
That'd be a full time job for someone |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
I wonder if this issue is related to the air suspension on the RRS. The suspension has a tolerance such that even if the car is nominally sat level, each wheel can effectively have a different height relative to the body. As the geometry changes with chaning ride heights, in effect one could have a vehicle with different geometries on each corner. Drive slowly across uneven ground keeping the wheel straight and you can feel the wheels pulling left and right as the front wheels take up different ride heights (and thus camber settings etc.).
Makes sense RRSTDV8, but you would have thought that they carry out the check with all corners set to zero, ie no air in them (must be easy to do at the factory |
This is begining to look like another Land Rover 'feature'.
