Home > Technical > the rear drops after a day or two
dynoick
2009 Range Rover Sport TDV8 HSE Java Black
hi there can you please tell me is this normal or is there a fault with the pump as the car drops to its axal in the rear after a day (8 hours) its under warranty with an after market company , what do you think?
Post #339164 Sun Apr 08 2012 11:59am
sounds like you have a leak somewhere... RRS gone
Post #339215 Sun Apr 08 2012 7:50pm
aljo
Re: the rear drops after a day or two
had same problem on a d3 , but whole car dropped over night , disconected battery overnight to eliminate electrics and front end only was down in morning , pulled the 3 air pipes off front valve block and did a vacum test on pipes,with no leaks , which narrowed it down then to the front valve block and replaced with success Thumbs Up
Post #339284 Mon Apr 09 2012 8:36pm
