![]() | Home > Technical > the rear drops after a day or two |
sounds like you have a leak somewhere... RRS gone
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
had same problem on a d3 , but whole car dropped over night , disconected battery overnight to eliminate electrics and front end only was down in morning , pulled the 3 air pipes off front valve block and did a vacum test on pipes,with no leaks , which narrowed it down then to the front valve block and replaced with success ![]() |
