Home > Technical > Intermittent HDC Fault On Startup |
firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461 |
start the car, with no brake pressed, does it do it then, if not press the brake see if that fires it, i had it a few days ago tuned out to be the brake switch, simple fix.
Wed Apr 04 2012 7:27pm |
chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219 |
It does it without putting your foot on the pedals. |
Wed Apr 04 2012 7:33pm |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 |
Battery and/or alternator goosed. If it's the original battery it's telling you it's had enough. |
Wed Apr 04 2012 10:05pm |
Ok thanks guys.
Wed Apr 04 2012 10:07pm |
If it was me I'd stick to the OEM one. The D3/RRS alternator works at a higher voltage than normal some batteries can't take that. The LR ones have a 3 year warranty and you can get 10% off with Allegance Discount. |
Wed Apr 04 2012 10:12pm |
OK guys,
Fri Apr 06 2012 8:03pm |
Big ken Member Since: 14 Nov 2011 Location: Airdrie Posts: 282 |
I got this falt when the battery was knackered, changed the battery and everything was fine.
Fri Apr 06 2012 8:15pm |
mark hamster Member Since: 26 Nov 2011 Location: nottingham Posts: 116 |
hi chapman.still can not post photos..! please advice me again,thanks |
Fri Apr 06 2012 8:16pm |
Photobucket.com
Fri Apr 06 2012 8:19pm |
Big Ken:-
Fri Apr 06 2012 8:21pm |
Fri Apr 06 2012 8:49pm |
so chapman,what you think.? SNAP |
Fri Apr 06 2012 8:50pm |
thanks for help,bingo |
Fri Apr 06 2012 8:53pm |
Looks spot on mate.
Fri Apr 06 2012 8:55pm |
