Home > Maintenance & Modifications > 11mdl 3.0ltr diesel engine oil. |
oxford-boy Member Since: 10 Nov 2011 Location: Oxford Posts: 148 |
4x4 dealer garage? 2005 Range Rover Sport TDV6 HSE in Artic Frost. 20" 2010 HST Alloys, sidesteps, Hawke tips, plus minor bits and bobs along with a remap. Four spike spiders ready for the Alps again now tucked up in their garage boxes... |
Tue Mar 27 2012 6:49pm |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 |
You could be asking for trouble from the "diesel particulate filter" by using the wrong engine oil. So make sure what was used is a low SAP's oil which conforms to WSS-M2C934-B as shown in the handbook. The oil you mention they used does not conform to the correct spec so I would get it changed as soon as possible.
Tue Mar 27 2012 10:19pm |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 |
Thanks oldcro. They are going to change it to the right spec oil. SVR 2018 in Santorini Black. |
Wed Mar 28 2012 9:04am |
If its not the correct spec its more than you DPF its your warranty - i saw the letter and the TSB reminding the correct spec oil to be used.
Wed Mar 28 2012 9:18pm |
All sorted guys. Castrol EDGE Professional C1 with the correct code! SVR 2018 in Santorini Black. |
Fri Mar 30 2012 6:10pm |
