Home > Maintenance & Modifications > 11mdl 3.0ltr diesel engine oil.
SVR575
Just had a oil and filter change at my local garage and they have put Castrol Magnatec 5W-30 fully synthetic oil in it. It is ACEA A1/B1 WSS-M2C913-A,B AND C.approved.They say this is OK. But in the hand book it is another code. Should i get them to drain this out again? Thanks in advance. SVR 2018 in Santorini Black.
Post #338031 Tue Mar 27 2012 5:37pm
oxford-boy
United Kingdom 2005 Range Rover Sport TDV6 HSE Arctic Frost
4x4 dealer garage? 2005 Range Rover Sport TDV6 HSE in Artic Frost. 20" 2010 HST Alloys, sidesteps, Hawke tips, plus minor bits and bobs along with a remap. Four spike spiders ready for the Alps again now tucked up in their garage boxes...
Post #338036 Tue Mar 27 2012 6:49pm
oldcro
Scotland
You could be asking for trouble from the "diesel particulate filter" by using the wrong engine oil. So make sure what was used is a low SAP's oil which conforms to WSS-M2C934-B as shown in the handbook. The oil you mention they used does not conform to the correct spec so I would get it changed as soon as possible.
I tried to buy some of the same oil from my local Ford/Mazda dealers who should be very familiar with it. The store man had never heard of it, but he did mention they had lots of problems with Diesel Particulate Filters. I wonder why...
The local Landrover repair garage also sold me a litre of the wrong oil so no guarantee they know any better.
opieoils.co.uk sell two makes of the correct oil.
Millers Oils XF Longlife C1 5w-30
Shell Helix Ultra AF-L 5w-30 Fully synthetic low SAPS engine oil.
Post #338054 Tue Mar 27 2012 10:19pm
SVR575
Thanks oldcro. They are going to change it to the right spec oil. Thumbs Up SVR 2018 in Santorini Black.
Post #338065 Wed Mar 28 2012 9:04am
mse
If its not the correct spec its more than you DPF its your warranty - i saw the letter and the TSB reminding the correct spec oil to be used.
Personally i wouldnt accept the lower spec. If it was an LR dealer they should use the correct stuff Mike
2014 Facelift Discovery
Post #338138 Wed Mar 28 2012 9:18pm
SVR575
All sorted guys. Castrol EDGE Professional C1 with the correct code! SVR 2018 in Santorini Black.
Post #338335 Fri Mar 30 2012 6:10pm
