Home > General > New Car |
Hugh Haddow Member Since: 03 Jul 2009 Location: Prestwick Posts: 202 |
Finally got the new RRS 3.0 HSE. and have clocked up 460 miles in 5 days. Can't stop driving the thing. It seems so much better than the previous 2.7.
Thu Mar 22 2012 5:14pm |
I'm finding the 8 speed box a little bit errrr well put it another way on approach to a roundabout or junction and its clear to continue without actually stopping you put your foot down and it has to think about it before it decides what gear to select by the time its decided what gear to choose because it doesn't respond immediately i put my foot down further to make the thing respond and then it takes off like a bullet not ideal if you are carrying clients, surely it should respond better than this but if you don't put your foot down just enough it sounds like its trying to pull in too higher gear which it is its as though its lacking throttle response, anyone else noticed this with the 8 speed box they say the gearbox learns your driving style but is this the case with the 8 speed box or has my box got dyslexia |
Thu Mar 22 2012 8:58pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Ady - Maybe the gearbox has learnt your style and has just decided you're...............errr......... a bit.........a bit of a hesitant driver
Fri Mar 23 2012 2:34am |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 |
I clocked up 600 miles in the 2 weeks I had left on leave and didn't notice any lag in the drive train take up. I had a Volvo XC90 before and this was terrible for a power/drive lag when you pulled out of a junction or entered a roundabout.
Fri Mar 23 2012 4:08am |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
I was under the impression it learnt your style ============
Fri Mar 23 2012 8:17am |
Can't say I've noticed this gearbox feature. Mind you I'm still being a little gently yet. New car and all that. Now up to 643 miles. Mini tour to Oban yesterday. Just can't fault it as yet. It thinks it's doing 37 MPG???? I'll check that shortly. Seems a bit questionable but don't care. other than the tax ripoff. OOps musn't be grumpy. |
Sat Mar 24 2012 2:08pm |
