Home > Technical > xenons adjustable?
SVR575
xenons adjustable?
My head lights seem a little low is there any way of adjusting them? Thanks. SVR 2018 in Santorini Black.
Post #337038 Mon Mar 19 2012 1:18pm
I think the xenon bit is controlled by the suspension height readings to give a regulated level beam; it's not user adjustable. The main beam can be altered by adjusting 2 philips screws visible from above the light unit. One is obvious, the other is below a hole in a bracket/cross member. Adjust both the same way to change the vertical, one or other to control horizontal.
At least that is the case with my MY08.
I shall be adjusting the main beams on mine when I remember because I think it's a tad high at the moment. It's noticeable now I've put fresh bulbs in the main beams. 2012 SDV6 - it's missing a couple of cylinders
Post #337048 Mon Mar 19 2012 4:27pm
