Home > Technical > xenons adjustable? |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
I think the xenon bit is controlled by the suspension height readings to give a regulated level beam; it's not user adjustable. The main beam can be altered by adjusting 2 philips screws visible from above the light unit. One is obvious, the other is below a hole in a bracket/cross member. Adjust both the same way to change the vertical, one or other to control horizontal.
Mon Mar 19 2012 4:27pm |
