![]() | Home > Maintenance & Modifications > How to remove range rover sport body shell |
sam006 Member Since: 10 Sep 2011 Location: Kent Posts: 115 ![]() ![]() ![]() |
I believe this is correct, at one point i thought i had a blown turbo which also required removal of the body shell. I'm sure someone posted either pics or a video up on here of 'how to' will have a good look. Otherwise pretty certain i found a video clip on YouTube.
djbigz Member Since: 17 Mar 2012 Location: London Posts: 8 ![]() ![]() ![]() |
Thanks mate is there a link you have for step by step instructions on how to remove the shell |
Blocked from YouTube at work (catching up on paperwork this weekend from the office) if you type in 'removing range rover sport body shell' a video should come up where they had to carry this out due to a blown turbo. Range Rover Sport HSE and for a bit of weekend fun a S1 Lotus Elise with a few track biased additions! |
Thanks mate i've seen that video but it not much help it only shows the lifting of the body i need to know how its done ive looked every where on the net but cant find any info |
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 ![]() ![]() |
TOPIx is your friend until the Haynes Manual comes out*
