Home > General > Urgent - Help!
Marc31
Urgent - Help!
My beloved RRS is due into the body shop tomorrow after some clown reversed into me, smashing the rear drivers side corner.
As a result, I've had to purchase a brand new rear apron Sad
Unfortunately now, the boot wont open and the battery is being constantly drained. Has anybody any ideas before I incur further cost by sending it in to my local LR garage???
Also, the parking sensor assistance has stoped working too Big Cry
Sensible helpful answers only please Smile
Post #336639 Thu Mar 15 2012 9:37am
Is the boot not opening because of the battery drain or because of the accident Question I'm sure the boot will need power from the battery to open the boot. There maybe a wire broke on one of the parking sensors Idea
Post #336657 Thu Mar 15 2012 10:50am
Marc31
Thanks for the response Smile
No, quite simply since the bump, the boot will not open. If I dont start the engine for a day or so, the battery goes flat so I presume there is a connection between the two?! Maybe a lose wire or something
Just wondered if anybody had experienced a similar scenario...
Post #336661 Thu Mar 15 2012 11:35am
essexfarmer
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Orkney Grey
Found this in another post, not sure if it's that helpful as you say your parking sensors dont work either but here goes anyway:
"not sure if this will help,but ive had a drain on mine as well called the aa out twice to jump
start me after i had not use the beast for 24hrs,now after that i noticed that the tailgate
would not open,searched for any hints and it seems there is a known problem with the boot
latch corroding and remaining live so draining the battery,so try your upper boot release if
its not working that may be it,worth a try." 12MY RRS Orkney Grey HSE Lux
12MY FF Santorini Black VSE
Post #336663 Thu Mar 15 2012 11:59am
Marc31
Oh mate, thats really great help. I'll feed that info over to the body shop guys now and see if they can fix it instead of me messing taking it to the LR garage.
I really appreciate your help!! Very Happy
Post #336667 Thu Mar 15 2012 12:17pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
my boot actually stopped working entirely and I claimed under the LR warranty for a new one. There's something odd like a wire/circuit that runs through the tailgate glass? and a control junction box. ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #336670 Thu Mar 15 2012 12:24pm
baxc
marc it will be you upper tailgate switch that is causing your battery drain if the switch is corroded this will drain your battery and stop your boot from opening Thumbs Up
Post #336674 Thu Mar 15 2012 12:37pm
