Home > General > Rear Camera - yellow guide lines
pacmeoff
All,
I took delivery of my 2012 RRS on Friday but I noticed today when reverse is selected the camera (rear view) is shown on the screen but the yellow lines do not move they remain straight.
I would have expected these yellow guide lines to move with the steering wheel as per my old Jaguar XF.
Do I have a fault?
Thanks
Paul.
Post #336065 Sun Mar 11 2012 12:03am
oldcro
Scotland
They certainly move with the steering on my MY11 so looks like you have a fault. Hope your dealer is not too far away.
Post #336069 Sun Mar 11 2012 12:30am
The lines only move if you have the surround cameras.
If you just have the reversing camera, the lines stay straight. I asked a similar question and was told that by James from Lookers PR.
Seems a little silly as it can't be that difficult to activate, just seems its something they hold back unless you opt for surround cameras. Rolling Eyes ON THE WAY: BMW F21 M140i
Post #336075 Sun Mar 11 2012 2:24am
pacmeoff
oldcro do you have surround view?
My old XF (which I assume is the same) only had the rear camera and the lines moved when I turned the wheel.
Paul.
Post #336078 Sun Mar 11 2012 3:23am
Lookers Park Royal
LR is different to Jaguar. As Beancounter has advised, the guide lines only move if you have the surround camera system.
James Thumbs Up
Post #336083 Sun Mar 11 2012 8:49am
oldcro
Scotland
Paul.
Yes I do have the surround cameras, although I'm surprised that it is needed to get moving guide lines. Not that I chose the option so my yellow lines could move with the steering you understand. Whistle Laughing
Post #336095 Sun Mar 11 2012 1:19pm
I'm guessing this would be a very simple exercise for LR to activate on non surround camera equipped cars.
Anyone heard of anyone that has done this on MY12 Question ON THE WAY: BMW F21 M140i
Post #336104 Sun Mar 11 2012 4:12pm
chesterfield
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
This seems quite silly to me too. The system in the XF seems almost identical to the one in the RRS. From audio to navigation. Moving lines would seem to be a very simple change indeed.
If Jaguar rolled it out as an "update" when the cars went in for a service (customers choice) then it would certainly not do the brand and customer loyalty any harm indeed. Not that it requires it in my view at present, but its a thought. RRS 3.0D HSE 11MY - Fuji White, a few extras.
Post #336126 Sun Mar 11 2012 8:25pm
pacmeoff
All,
Many thanks for all your replies, It seems uttlerly stupid to me why put the yellow lines on at all if they are not going to move.
Most odd
Paul.
Post #336139 Mon Mar 12 2012 12:41am
I never use my rear view camera, i reverse using my mirrors, and always have,
Post #336159 Mon Mar 12 2012 11:08am
betty02
Is there no software out there for RR's like there is for many other cars, for example for Volkswagen they have something called VAG-COM/VCDS and it's a programme that will let you change this such as this, as well as loads of other things and most manufacturers seam to have them so surprised RR doesn't?
maybe speak to someone who offers the RR Sport lowering and see if they have the tool to read the CAN-BUS data, then trick it into thinking you have full system, probably just a simple binary change from a 0 to a 1!
HTH!
Post #336172 Mon Mar 12 2012 11:30am
^^^ There is software (eg faultmate) but none at present to crack the MY12 I believe Sad ON THE WAY: BMW F21 M140i
Post #336173 Mon Mar 12 2012 11:32am
betty02
Agh my bad, is faultmate just a fault code reader or can you go into more depth and change things such as DRl power, seatbelt chimes etc?
Post #336181 Mon Mar 12 2012 11:59am
Not that sure to be honest Betty, never seen it in action or used it.......
But I can help with seatbelt chimes Thumbs Up ON THE WAY: BMW F21 M140i
Post #336190 Mon Mar 12 2012 12:29pm
betty02
Agh sorry wasn't really after changing them was just an example of the things that you can change using certain software, I'm still trying to get rid of my MK5 Golf GTi before I dip into the RRS!
Post #336193 Mon Mar 12 2012 1:09pm
