![]() | Home > General > Rear Camera - yellow guide lines |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 ![]() ![]() |
They certainly move with the steering on my MY11 so looks like you have a fault. Hope your dealer is not too far away. |
The lines only move if you have the surround cameras.
pacmeoff Member Since: 27 Jan 2012 Location: UK, Midlands Posts: 11 ![]() |
oldcro do you have surround view?
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 ![]() |
LR is different to Jaguar. As Beancounter has advised, the guide lines only move if you have the surround camera system.
Yes I do have the surround cameras, although I'm surprised that it is needed to get moving guide lines. Not that I chose the option so my yellow lines could move with the steering you understand. ![]() ![]() |
I'm guessing this would be a very simple exercise for LR to activate on non surround camera equipped cars.
chesterfield Member Since: 14 Jul 2011 Location: Chesterfield Posts: 123 ![]() ![]() ![]() |
This seems quite silly to me too. The system in the XF seems almost identical to the one in the RRS. From audio to navigation. Moving lines would seem to be a very simple change indeed.
All,
I never use my rear view camera, i reverse using my mirrors, and always have, |
betty02 Member Since: 26 Jan 2009 Location: Blackpool Posts: 28 ![]() ![]() |
Is there no software out there for RR's like there is for many other cars, for example for Volkswagen they have something called VAG-COM/VCDS and it's a programme that will let you change this such as this, as well as loads of other things and most manufacturers seam to have them so surprised RR doesn't?
^^^ There is software (eg faultmate) but none at present to crack the MY12 I believe |
Agh my bad, is faultmate just a fault code reader or can you go into more depth and change things such as DRl power, seatbelt chimes etc? |
Not that sure to be honest Betty, never seen it in action or used it.......
Agh sorry wasn't really after changing them was just an example of the things that you can change using certain software, I'm still trying to get rid of my MK5 Golf GTi before I dip into the RRS! |
