Home > Technical > for the EAS control tool users
impreza54
France 2007 Range Rover Sport TDV8 HSE Java Black
quick question: how much do you lower your RRS?
I started with -30mm and was thinking if it's not too much? If I can go lower? Please give me your opinion.
Thanks Range Rover Sport TDV8 HSE Premium
Post #332539 Wed Feb 15 2012 9:55am
Baben
South Africa 2012 Range Rover Sport Supercharged HSE Alaska White
I have been playing around with suspension height settings for a while now using my Faultmate. But it seems like the damping becomes worse (bouncier) as I lower the suspension, and after 30mm it is real bouncy. I am on about 15mm lower than standard right now, and the ride is fairly nice.
Are you experiencing the same, or are my shocks/dampers perhaps worn?
regarding your question - I found that after 30mm lower, the suspension would create errors over small bumps, and raise to extended height, probably cos it hits the end of travel, or the height sensor values are illegal ?
for interest' sake, what is your absolute height from the top of the wheel rim to the underneath of the wheel arch at your current setting? not all RRS are the same "standard" height - there seems to be slight differences up to 10mm
Post #332541 Wed Feb 15 2012 10:11am
I'm at -25mm and that's as much as my B road commute will stand before it gets "bouncy"
30 looks Cool but the ride quality is tragic RRS gone
Post #332576 Wed Feb 15 2012 1:34pm
