Home > General > Which trolley jack and stands should I buy |
sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690 |
Guys
Mon Feb 06 2012 4:57pm |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
3 tonnes would be ok, 4 tonnes better, 5 even better, but price goes up quickly!
Mon Feb 06 2012 5:08pm |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
one tonne will lift the RRS (wheels are rated at approx 900kg per corner) but to be on the safe side i would go for a 3 Tonne, then you can lift the entire front or rear rather than just one corner. if your wanting axle stands you will require 2 tonne. |
Mon Feb 06 2012 5:17pm |
JUCOTT01 Member Since: 12 Aug 2010 Location: GLASGOW Posts: 89 |
This is the one i have
Mon Feb 06 2012 5:43pm |
bigphil99 Member Since: 14 Dec 2011 Location: N. Ireland Posts: 17 |
I have the same sealey jack. Its a great job. Go to your local motor factors and you should get one for close to £100. Sealey tend to do deals where they throw in axle stands with jacks for a bundle price. |
Mon Feb 06 2012 6:48pm |
Ave just seen one for £92 new. TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Mon Feb 06 2012 7:43pm |
The sealey 3003CXQ is a rocket lift which means the lift arm rises in a couple of strokes ,ideal for 4x4's where there is a bigger ground clearance
Mon Feb 06 2012 7:48pm |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 |
Also, any ideas ref replacing the garbage scissor jack with a good bottle jack? My Defender had one which I should have retained...and yet the RRS comes with an Austin Allegro/Mini 850 scissor jack which is nearly incapable of lifting one side, even when the suspension is set to off road height..as per manual. |
Mon Feb 06 2012 8:03pm |
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 |
Sherlock
Mon Feb 06 2012 9:06pm |
Was beginning to think that myself. Would the likes of HSS do that sort of thing? TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Mon Feb 06 2012 9:22pm |
Am confused.com now.
Mon Feb 06 2012 10:03pm |
You asked for advise on purchasing a suitable jack for a 4x4 and you got some good advise
Mon Feb 06 2012 10:17pm |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
I have THIS 3 ton one from Halfords. Cost about £75 with my trade card.
Mon Feb 06 2012 11:26pm |
fair point! I need to get off the fence then and buy a decent one. Thanks for all the advice gents. TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx 20" HST alloys, Privacy glass, Side steps, Xenon Adaptive Lighting, Adaptive cruise control |
Tue Feb 07 2012 12:22am |
