![]() | Home > General > Which trolley jack and stands should I buy |
sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690 ![]() ![]() |
Guys
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
3 tonnes would be ok, 4 tonnes better, 5 even better, but price goes up quickly!
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
one tonne will lift the RRS (wheels are rated at approx 900kg per corner) but to be on the safe side i would go for a 3 Tonne, then you can lift the entire front or rear rather than just one corner. if your wanting axle stands you will require 2 tonne. |
JUCOTT01 Member Since: 12 Aug 2010 Location: GLASGOW Posts: 89 ![]() ![]() |
This is the one i have
bigphil99 Member Since: 14 Dec 2011 Location: N. Ireland Posts: 17 ![]() ![]() |
I have the same sealey jack. Its a great job. Go to your local motor factors and you should get one for close to �100. Sealey tend to do deals where they throw in axle stands with jacks for a bundle price. |
Ave just seen one for �92 new. TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
The sealey 3003CXQ is a rocket lift which means the lift arm rises in a couple of strokes ,ideal for 4x4's where there is a bigger ground clearance
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 ![]() ![]() |
Also, any ideas ref replacing the garbage scissor jack with a good bottle jack? My Defender had one which I should have retained...and yet the RRS comes with an Austin Allegro/Mini 850 scissor jack which is nearly incapable of lifting one side, even when the suspension is set to off road height..as per manual. |
ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392 ![]() ![]() ![]() |
Sherlock
Was beginning to think that myself. Would the likes of HSS do that sort of thing? TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Am confused.com now.
You asked for advise on purchasing a suitable jack for a 4x4 and you got some good advise
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
I have THIS 3 ton one from Halfords. Cost about �75 with my trade card.
fair point! I need to get off the fence then and buy a decent one. Thanks for all the advice gents. ![]() 20" HST alloys, Privacy glass, Side steps, Xenon Adaptive Lighting, Adaptive cruise control |
