Home > Technical > Drivers door not locking
russfenwick
England 2006 Range Rover Sport TDV6 SE Zermatt Silver
I am experiencing an issue where the driver's door fails to lock. It appears that the inner lock lever/button isn't returning fully when the door is opened from the inside and therefore does not fully 'engage' into the recess above the door release handle when the remote operates the central locking. (Does that make sense?). If I push the lever in before I shut the door, it works fine. Has anyone come across this or have any advice please?
What I do plan to do is remove the trim and check for the any mechanism issues which brings me to my next question:
Can anyone assist with the location of the fixings to enable the removal of the door panel please?
Many thanks in advance.
Russ Russ
Post #329944 Sat Jan 28 2012 6:24pm
rajhirani
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Fuji White
had the same issue with mine, dealer replaced the lock motor part, and now it works fine.
Regards, RRS MY2012 AutoBiography
Post #329948 Sat Jan 28 2012 6:35pm
Common problem i'm afraid, ive had both my front doors done under warranty.
Post #329956 Sat Jan 28 2012 7:56pm
Martin
Site Administrator & Owner
See http://www.disco3.co.uk/forum/topic33743.html for the Discovery 3, RRS should be very similar. Like this site? Buy some RRSPORT goodies to show your support!
Post #329965 Sat Jan 28 2012 9:26pm
