Home > Technical > Suspension Knock, Mass Dampers |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
That's rubbish - my mass dampers were fitted under warranty earlier this year. It's a modification to sort out an inherent and acknowledged problem, and that's a legitimate warranty claim. have a look in Bobby's gallery as Im pretty sure there will be a technical bulletin from LR you can wave under the stealers nose. FF 4.4 V8 Soooo looking forward to this bad boy
Wed Oct 12 2011 12:29pm |
ARHRRS Member Since: 14 Jan 2010 Location: Birmingham Posts: 36 |
Is that Bulletin LTB00241v3/2011 that mentions the Mass Absorber kit LR023280 |
Wed Oct 12 2011 1:40pm |
I have just told that because the car is under the Land Rover Approved warranty it is not covered but if it was covered by the Manufacturer's Warranty it might have been covered.
Wed Oct 12 2011 3:07pm |
Collected my car on Friday after having the bushes replaced and the mass dampers fitted and it is a totally different car. The suspension is now so quiet with no knocking what so ever.
Mon Oct 17 2011 11:19am |
Benidorm Mick Member Since: 27 May 2010 Location: Wiltshire Posts: 102 |
Not fitted?? Just the parts, right? |
Wed Jan 25 2012 2:23pm |
Mines had the mass damper fitted a couple of years ago. In today (local garage not LR) getting ARB bushes replaced. Question.... Does the mass damper wear out and need replaced again?? Knockings driving me nuts |
Wed Jan 25 2012 2:39pm |
RRS-Spy Member Since: 01 Nov 2011 Location: London Posts: 169 |
What is teh knocking everyone is referring to ?
Wed Jan 25 2012 6:42pm |
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 |
The mass dampers do not wear out as they are simply two 6kg blocks of cast steel bolted to existing holes in the chassis just in front of the No 2 body mountings each side of the car. It should not take more than 5-10 minutes to fit each one once the vehicle is raised high enough for access underneath.
Wed Jan 25 2012 10:04pm |
Thanks Bob. Had the bushes done yesterday and seems to have solved the knocking... thanks the lord.. However, took it up the M5 afterwards for a wee sprint test and getting some vibration through the steering wheel and a slight pull to the left. Vibration from about 60 upwards. Do you know if this is normal post bush replacement and what's the way forward? cheers |
Thu Jan 26 2012 9:12am |
SPY... You'll know it when you hear it... and i do mean "when" |
Thu Jan 26 2012 9:34am |
New ARB bushes would not cause these problems. The ARB has no effect on a vehicle going in a straight line.
Thu Jan 26 2012 8:26pm |
Yeah it was fine before the work bob.. anyhoo, update... took it back to the grarage and they took the front wheels of to check the balance. one was 40g out and the other 80 apparently
Mon Jan 30 2012 8:45am |
johnunleashed Member Since: 13 Jul 2014 Location: Lancashire Posts: 59 |
hello will this mass damper fit to a 2007 range rover sport , many thanks for your time |
Thu Oct 09 2014 1:30pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9005 |
It should already have them fitted... 2012 SDV6 - it's missing a couple of cylinders
Thu Oct 09 2014 8:02pm |
