![]() | Home > Technical > Suspension Knock, Mass Dampers |
johnunleashed Member Since: 13 Jul 2014 Location: Lancashire Posts: 59 ![]() ![]() |
the answer is yes , if you ask landrover they will say no , mine where from a 2011. ,ebay from a landrover dealer 2007 SUPERCHARGED HST |
hse-lee Member Since: 17 Jan 2015 Location: london Posts: 77 ![]() ![]() ![]() |
well i feel like crying and then taking a match to the damn thing & roasting some marsh mallows on it, just crawled under car and it actually has the mass dampers already fitted |
not sure about the bolts on the rear damper's , The rear damper's should move tho and not be solid . but defo check the shocker's behind the front wheel arch's have been taken off , they are a 10min job to remove . 2007 SUPERCHARGED HST |
