Home > Maintenance & Modifications > EAS control unit anyone used one?
shane159
I've just took delivery of my EAS control unit from here:
http://www.lrparts.net/pp/RANGE_ROVER_SPOR...SPORT.html
Thing I'm wanting to know is the standard driving hight is 18 1/2 inch from center of the wheel to top of the wheel arch.
Using this control drops it to 17 3/4 inch to the same position, this is not even as low as the access hight on standard settings that is 16 1/2 inch.
Just wondered if anyone has used one if they got there's to around the same hight as the access settings???
Thought this was a better option than the suspension link
Post #329252 Mon Jan 23 2012 8:41pm
felstmiester
United Kingdom 2005 Range Rover Sport TDV6 HSE Santorini Black
Why would you want to lower it to access hight?? You surely can't be thinking your going to be driving it around at that hight? You'll be bouncing all over the road! When I pull off my drive and mines in access hight, until it raises I feel I look a bit of an idiot driving up my road bouncing on the bump stops. Lol.
Post #329272 Tue Jan 24 2012 7:03am
shane159
Each to there own mate, I just feel the car looks better with the wheels filling the arch's (and I'm not a chav) just a personal preffrence.
My RR only covers a small amount of miles a week around 40 to 50 so this wouldn't be to much of a issue to be honest.
Post #329273 Tue Jan 24 2012 7:07am
felstmiester
It's not that I don't think the range looks better at access hight. Whenever I park that's the first thing I do is drop it to access, not because it's easier getting in and out, just cause it looks better. But have you tried actually driving for any distance when on access hight? It would shake you and the car to oblivion. And I would say it would be dangerous to drive.
Post #329274 Tue Jan 24 2012 7:22am
Supacat
Don't you need to re-calibrate the vehicle ride height after fitting this part?
Post #329275 Tue Jan 24 2012 7:37am
felstmiester
I'm not sure what exactly the control unit does other than allow you to lower the range. But I would've thought there is no need to calibrate anything as the control unit should do this for you. I remember with the old p38's you used to be able to get a diagnostic lead to plug in a lap top and a program that loaded up so you could set them at the required hight you wanted. I would think this control unit is the same sort of thing.
Post #329343 Tue Jan 24 2012 4:41pm
I'm using one at the moment
-25mm and yes it makes the 22's look less "lost" in the wheelarches
Ride height is slightly firmer
Access height will not stay lowered if you've lowered it more than 22mm on the 05-07 cars (go's into extended mode)
But I find I do not use access anyway once it's lowered, so real no issue
I've tried a -29mm adjustment which looked "bang on" for a motorway style height but the suspension was shocking ( Access mode quality) so -25mm is maximum if you wish to keep your fillings in. Thumbs Up RRS gone
Post #329391 Tue Jan 24 2012 9:35pm
and no callibration is needed
It just backs up your vehicle's current settings... then adjusts them by the requested amount (+40 to -40 iirc)
The car can be returned to standard by the clicking in the menu. RRS gone
Post #329393 Tue Jan 24 2012 9:38pm
felstmiester
That sounds good as it goes. So can you explain where it's plugged in and how you use it. Is it something that you leave plugged in and can adjust hight whenever you want or is it a plug in and set it then unplug??
Post #329410 Tue Jan 24 2012 10:21pm
sherlock
2008 Range Rover Sport TDV8 HSE Santorini Black
AWD Man, is this a simple plug and play module or do you link it into a laptop or something to set it? TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
20" HST alloys, Privacy glass, Side steps, Xenon Adaptive Lighting, Adaptive cruise control
Post #329414 Tue Jan 24 2012 10:44pm
shane159
Finally I've sorted mine out, the American based company are so helpful it's unreal.
These things are so easy to use I think for £200 there well worth it!!!
No laptop or anything needed just plug and play, the module has 3 internal memory positions so it can save your 3 favorite settings aswell as keeping the standard setting.
It takes 30 seconds from plugging it in to adjusting the suspension and unplugging again.
Post #329428 Wed Jan 25 2012 7:08am
shepp
Hello shane
The unit from gap diagnostics is a great bit of kit. All manuals are downloadable from gap-diagnostics.com. The normal height for mine is 200mm from edge of rim to wheel arch.
There are quite a few posts on the unit, as the developers asked for some beta testers last October.
Post #329429 Wed Jan 25 2012 8:23am
Locates in the ODB port (under the steering column) with the engine off and ignition on. Thumbs Up
EAS Menu is then selected via the cruise control buttons on the steering wheel.
Once the settings have been changed, turn off ignition and remove EAS (no need to re-insert it
Thumbs Up RRS gone
Post #329469 Wed Jan 25 2012 12:25pm
sherlock
and is the menu displayed on the EAS or the centre menu on the dash TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Post #329474 Wed Jan 25 2012 12:55pm
Dash mate
The menu is accessed through the steering wheel c/control switches and viewed via the dash display
Once the new height info is inputed, just turn off the ignition and remove the EAS from the ODB port... no need to re-insert it unless you want to run EAS again. Thumbs Up RRS gone
Post #329501 Wed Jan 25 2012 2:51pm
