Home > My Range Rover Sport > Update: 2 months on.....MY2012 SDV6
Page 4 of 4 <1234
WolfgangK wrote:
@ beancounter
is there a difference in comfort between the normal programm and the dynamic response ? May be I could change my order to get these feature.
Thanks,
WolfgangK
WolfgangK wrote:
@supacat
I must drive both systems, to feel the difference. Here in Germany it is an option with 3k € . If someone drove both systems, please let me hear your opinion.
WolfgangK
You can definitely feel the car stiffen up in Dynamic mode, its a firmer ride, less roll into the corners etc, there also sharper throttle and steering too.
The 'Dynamic' pack is standard on all but the 'SE' in the UK. Even then you can spec it as a £2,205 option.
Could be worth checking if your new car will have it as standard, or try and test drive them to see if you want to spec it if it not on there. ON THE WAY: BMW F21 M140i
Post #326953 Thu Jan 05 2012 10:43am
WolfgangK
Germany 2012 Range Rover Sport SDV6 HSE Nara Bronze
@ beancounter
I ordered the HSE, but in Germany the Dynamic Response is an option. Only the V8 SC has it standard.
WolfgangK
Post #326955 Thu Jan 05 2012 10:52am
Jonny Fresh
So if I have Dynamic response (which I do) should I be driving in it all the time?
Post #326956 Thu Jan 05 2012 11:31am
Not if you are on the motorway, but if you are on twisty roads then yes, it makes a big difference Thumbs Up
Post #326960 Thu Jan 05 2012 11:55am
What he said Thumbs Up ON THE WAY: BMW F21 M140i
Post #326965 Thu Jan 05 2012 12:06pm
Jonny Fresh
I'll give it a whirl next time Thumbs Up
Post #327086 Fri Jan 06 2012 9:18am
andman
Andorra 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
I drive to Barcelona at least once a week.... 2hrs of winding mountain roads and passes.....French spec lhd doesn't include the DP... and so happy I ordered the dynamic pack ... it keeps the car so firmly planted and connected to the road on the fast gentle bends... and on the tight u bends just seems make the front end seem that little bit lighter than the 2++ tons it is ...
2012 HSE arctic /black/ cont stitch/ piano /Diamond T
2010 Porsche Boxster S 3.4 (in garage for winter)
Post #328986 Sat Jan 21 2012 3:01am
Supacat
The brochure implies the changes to throttle and steering only apply to petrol engine:
On 5.0 V8 Supercharged models the system can provide more performance-orientated responses to driver
input by remapping steering, throttle and gearbox settings.
Post #329088 Sat Jan 21 2012 11:48pm
Just found this on the RRS site:
"The Terrain Response® system includes Dynamic Programme (standard on LR-V8 Supercharged and optional on LR-SDV6 models), which can provide more performance-orientated responses to driver input by remapping steering, throttle and gearbox settings."
Seems theres an inconsistency in the literature, as I posted earlier on, this was from the RRS website.
Perhaps James/Steve could confirm Question ON THE WAY: BMW F21 M140i
Post #329097 Sun Jan 22 2012 7:24am
Lookers Park Royal
I'm at home today so not able to access my guides, however what I will say is that the steering response changes on my 3.0 AB when AD is activated. I was led to believe that it adjusted suspension, steering, throttle and gearbox on all models....... But I'll confirm next week.
James Thumbs Up
Post #329101 Sun Jan 22 2012 8:54am
Page 4 of 4 <1234
