![]() | Home > My Range Rover Sport > Update: 2 months on.....MY2012 SDV6 |
Triple7 Member Since: 27 Oct 2011 Location: Wiltshire Posts: 154 ![]() ![]() |
The 2010MY 3.0, although a TD, had the new twin, sequential diesel V6, replacing the single turbo of the 2.7. The SDV6 is still sequential in that it has a large and a small turbo in line. It is just a bit quieter & has a tweak to give it more power.
Thanks for clarifying Triple7, I didn't realise that the earlier engines have a twin turbo too.
Naz Member Since: 10 Mar 2010 Location: Birmingham Posts: 29 ![]() ![]() ![]() |
I've just sold my MY10 HSE and looking forward to the arrival of my MY12 in a few weeks, i found the turbo lag on my MY10 at low revs very annoying and found myself hesitating and not having the confidence at junctions when wanting to pull away quickly. Look forward to seeing if the new transmission and turbos improve this. Current: MY 12 HSE Autobiography Kit
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1678 ![]() ![]() ![]() |
My old petrol (4.2 SC) would often get confused at junctions when in traffic - accelerate slightly to the junction, lift off to check traffic to the right, then try and accelerate across the junction/enter the roundabout. Gearbox didn't know what to do and you'd end up drifting slowly into the road. Possibly due to the very low 1st gear and the gearbox programmed to be in 2nd asap unless stationary.
@ Naz - You'll definitely find the turbo lag is removed. My old 2.0 Tdi Audi would be the same, I have found that the RRS is very eager to set off and there's no lag at lower revs. Don't forget to get some pics up when you get your new one |
@ Beancounter_74 Thats good news and yes pictures will be up when it arrives, have a build date of 15.11.11 so not long now. Current: MY 12 HSE Autobiography Kit
@Beancounter_74 I hear that you can now stream audio from ur phone to the car as if the sound system were an oversized pair of bluetooth headphones, have you tried this?
Naz, Yes, have tried the bluetooth streaming from the wife's iPhone 3GS, works very well, although to be honest I prefer to use the cable to the USB port in the centre console (above the fridge |
supadipps Member Since: 14 Nov 2011 Location: gb Posts: 21 ![]() ![]() |
Looking good mate, Iv order pretty much the same, only differences are black leathers with contrast stitch and no tow bar.
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
Diamond cut alloys look good but mark up really easily and road salt seems to destroy the finish,it seems to get under the laquer very easily,also harder to get refurbed.Have a good look at some on used cars very few will be perfect.
Hmm, that don't sound too good. ![]() |
Thanks supadipps, I'm really pleased with it.
andy r Member Since: 04 Jul 2011 Location: Torbay Posts: 370 ![]() ![]() |
I had the rotary shift on the XF....hated it with a vengeance, all the poop and twitter, press the start button and it climbs out of the consol and the vents open, the amount of times I had it in the wrong place as well, levers are gooood, it does have a green oval after all 08 2.7 RRS "S"
Two months on.....
