Home > Technical > DRL Retrofit & CanBus
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
I fancy fitting a set of DRL's when i put the autobiography bumper on my 10MY Sport. LR kit is extortionate, so i plan to make up my own kit.
Question is has anyone fitted and aftermarket set and managed to get round the cambus issue??
Post #329024 Sat Jan 21 2012 6:35pm
big pimp
Surely it would just be a case of running them off a decent relay, which switches them on when power goes to the relay, and off when you switch sidelights on. I see you can even get ones which will dim down now when you go to sidelights which is pretty cool MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #329068 Sat Jan 21 2012 9:25pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Yes mine cause no issues with the canbus.
Post #329087 Sat Jan 21 2012 11:39pm
