Home > General > Transmission Fault & HDC Unavailable
Page 2 of 3 <123>
sweetafton
England 2011 Range Rover Sport Supercharged Santorini Black
+1 sorry to hear. They might give you a new courtesy RRS when they are fixing yours. Thumbs Up MY11 Autobiography supercharged. Santorini Black. Monaco interior. Rear screens. Privacy.
Gone MY08 Supercharged HST. Java black. Ivory premium interior. Rear screens. Privacy. Missed a lot.
Gone MY04 Discovery V8 Petrol ES Premium. Awesome.
Post #322154 Tue Nov 22 2011 3:57pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
DRDILL wrote:
The only coutsey car will be a freelander or a pergeot!
sad times Crying or Very sad
Post #322202 Tue Nov 22 2011 9:04pm
ajp166
sam006 wrote:
I just had near exactly the same problem, turned out to be an incorrect brake light bulb!!
Sam I think I had the same issue as you today.... put LED bulbs in my rear lights and the brake warning came up and then the transmission fault and Dynamic light came on (amber)... the car lowered and I couldnt raise the RRS... put the old bulbs back and everything seems ok... was that the same for you?
Post #322838 Sun Nov 27 2011 8:15pm
mlines
I had a similar problem on my 07 TDV6 HSE, rolled to a halt with Transmission and HDC errors, turned out to be the EGR valves on the engine! 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #323945 Sun Dec 04 2011 10:10pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
did you buy the car new? ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #328315 Mon Jan 16 2012 7:02pm
rrsboy
DRDILL wrote:
Classic case of not reading my posts!
a quick glance over, still can't find the answer. I found "Truck currently has 39k and is out of warranty" which doesn't help. If you bought it new from LR then you are in luck. ============
Post #328390 Tue Jan 17 2012 8:56am
rrsboy
good luck ============
Post #328400 Tue Jan 17 2012 9:04am
OUCH
That's really tough mate.
and as for WD... shame on them.... I thought the purpose of the top warranty was to ensure EVERYTHING was covered (I have the same cover)
Any idea on what the damage is going to be? RRS gone
Post #328406 Tue Jan 17 2012 9:15am
rrsboy
awd man wrote:
OUCH
Looking very briefly at the top WD policy http://www.warrantydirect.co.uk/pdfs/6727-...ryCare.pdf there's no reason this claim would not be met by it assuming you like a good fight. What is the difference between Luxury Care and Extra Care - which is the top WD one? ============
Post #328408 Tue Jan 17 2012 9:18am
Extra care has greater cover than Luxury Care
Limited to cars younger than 7 years old and 70k miles
usually you start on extra care then slip into Luxury care after a year or 2 Thumbs Up RRS gone
Post #328417 Tue Jan 17 2012 10:09am
rrsboy
I don't know what the difference is but the following wording means you have a case
"LuxuryCare
“Nearly a new car warranty” Almost all mechanical and electrical components of your vehicle are covered.
*The exceptional level of protection provides parts and labour cover for almost all the mechanical and
electrical components of your vehicle. This is one of the best extended warranty protection covers you can get
outside of the manufacturer’s warranty.
*LuxuryCare includes all mechanical and electrical components of your vehicle as insured parts covered against breakdown with the exception of those listed in Section “Items Not Covered” on page 6.""
Then in Not Covered for Miscellaneous Components it says:
"Auxiliary drive belts, brackets & mountings, cables, catalytic converters (unless additional cover is
confirmed on your policy schedule), casings (unless they have been damaged as the result of the breakdown
of an insured part), electrical connectors, engine covers, engine starting battery & all other batteries, fuel & fuel lines, fuses, heating elements & aerials integral with glass windows, hoses & pipes, hose clips & pipe
connectors, light bulbs & high-intensity discharge tubes (xenon), non-factory fitted alarms & immobilisers,
alarm entry switches, road wheels, wiper blades and any components not approved by the manufacturer and fitted by them, or fitted by their agents, when your vehicle was new and before it was first used."
Now, the CRITICALbit is, in Not Covered for In-car entertainment, telephone and navigation systems is says:
".....auxiliary wiring & connectors...."
So, by their own words, electrical wiring is NOT electrical connectors - the distinction is made. Therefore, fight it hard enough and you will get this through.
This assuming that Luxury and Extra are the same wording as above?
Ambiguity = Opportunity Thumbs Up ============
Post #328427 Tue Jan 17 2012 11:59am
Very good point made there RRS gone
Post #328432 Tue Jan 17 2012 12:13pm
rrsboy
I just looked at the Extra care pdf, quite surprised the structure of it is so different to the other one (I assumed they'd all be the same layout, but different lists of included/excluded). Extra seems to be a specific list of what is covered, everything else excluded - unfortunately can't find wiring on the list of what's included or the term electrical connectors Sad ============
Post #328525 Tue Jan 17 2012 10:16pm
Supacat
DRDILL wrote:
Hover over my picture and it says the model year
I've learnt something then Rolling Eyes
Post #328528 Tue Jan 17 2012 11:46pm
You must be well and truely p155ed off now Mr. Green i know i would be, good luck getting it sorted once and for all Thumbs Up
Post #330064 Sun Jan 29 2012 7:39pm
Page 2 of 3 <123>
