Home > Technical > Ticking sound coming from underneath
sherlock
2008 Range Rover Sport TDV8 HSE Santorini Black
Guys can you help please?
I have recently been hearing a loud ticking sound from underneath my TDV8 and raised it with the local Manchester dealer only to be told it was the little coolant heater engine and not to worry. To be honest though guys I'm not convinced.
It doesn't happen all the time and when it does it can last from as little as 10 seconds to a minute then stops. I was wondering if it could be an air suspension issue and whether I should go back the dealer and raise it again.
Any assistance much appreciated forum.
Post #328329 Mon Jan 16 2012 8:34pm
Or it could be your sat nav under the passenger seat. 2005 Zambezi TDV6 - Gone but not forgotten
Post #328333 Mon Jan 16 2012 9:03pm
sherlock
NO ITS DEFINATELY UNDER THE FLOOR AS ITS LOUDER WHEN THE WINDOW IS OPEN
Post #328334 Mon Jan 16 2012 9:05pm
simon1233
Probably is the fuel burning heater, they can make some funny clicks etc as they start up, after the clicks have stopped can you hear a sound like a small turbine engine? This is the noise the FBH makes.
To be sure, open your bonnet, start the car and then stand at the front passenger side, you can see the FBH on top of the wing, behind the headlight - is this making the clicking sound?
Post #328363 Mon Jan 16 2012 11:29pm
sherlock
Thanks. When it's back from the repairers I will do what you say. I'm hoping you are right actually as don't need any more surprises.
Post #328364 Mon Jan 16 2012 11:36pm
Kensta
When my egr valve packed up my only symptom was a ticking noise from the engine area it sounded like a tappet noise from an old ford engine, might be worth u looking into Sherlock Java black 2006
Post #328374 Tue Jan 17 2012 8:20am
sherlock
Egr again please? Sorry quite new to RRS.
Thanks
Post #328382 Tue Jan 17 2012 8:46am
Kensta
Exhaust Gas Recirculation valve. Common to break down on our cars Sherlock, easily fixed tho, mine made a loud tapping noise that quitend down after a short while, got them both removed and blanked off as they're un-necessary on the earlier TDV6, therers two of these valves fitted to the rangerover sport Java black 2006
Post #328391 Tue Jan 17 2012 8:56am
sherlock
Thanks
Post #328401 Tue Jan 17 2012 9:05am
mlines
under the floor sounds can be from the suspension compressor. 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #328403 Tue Jan 17 2012 9:07am
mlines
Post #328404 Tue Jan 17 2012 9:07am
sherlock
If it is the suspension is it a fault or just the regular sound?
Post #328429 Tue Jan 17 2012 12:03pm
chrisrrs59
Wales 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Mine does it when the suspension is lower and driving low speed sent it back they couldnt find the problems RRS 2010 model in Bali blue
Hse Spec with rear camera side steps
tinted windows
Audi A4 2008 Red with 19 inch wheels chrome mirrors tinted windows
Post #328438 Tue Jan 17 2012 12:52pm
Supacat
My next door neighbour actually made a point of speaking to m the other day about the RRS. he wanted to tell me that on several occasions when he had been out in the front garden he had heard my car making noises. Not just the same one but several different ones.
The car will wake itself up periodically and go through various routines and so can be a little disconcerting if you happen to be passing at the wrong moment.
Post #328554 Wed Jan 18 2012 9:47am
