Home > Technical > Ticking sound coming from underneath |
sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690 |
Guys can you help please?
Mon Jan 16 2012 8:34pm |
Or it could be your sat nav under the passenger seat. 2005 Zambezi TDV6 - Gone but not forgotten
Mon Jan 16 2012 9:03pm |
NO ITS DEFINATELY UNDER THE FLOOR AS ITS LOUDER WHEN THE WINDOW IS OPEN |
Mon Jan 16 2012 9:05pm |
Thanks. When it's back from the repairers I will do what you say. I'm hoping you are right actually as don't need any more surprises. |
Mon Jan 16 2012 11:36pm |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 700 |
When my egr valve packed up my only symptom was a ticking noise from the engine area it sounded like a tappet noise from an old ford engine, might be worth u looking into Sherlock Java black 2006 |
Tue Jan 17 2012 8:20am |
Egr again please? Sorry quite new to RRS.
Tue Jan 17 2012 8:46am |
Exhaust Gas Recirculation valve. Common to break down on our cars Sherlock, easily fixed tho, mine made a loud tapping noise that quitend down after a short while, got them both removed and blanked off as they're un-necessary on the earlier TDV6, therers two of these valves fitted to the rangerover sport Java black 2006 |
Tue Jan 17 2012 8:56am |
Thanks |
Tue Jan 17 2012 9:05am |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 |
under the floor sounds can be from the suspension compressor. 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
Tue Jan 17 2012 9:07am |
If it is the suspension is it a fault or just the regular sound? |
Tue Jan 17 2012 12:03pm |
chrisrrs59 Member Since: 15 Mar 2011 Location: caerphilly Posts: 170 |
Mine does it when the suspension is lower and driving low speed sent it back they couldnt find the problems RRS 2010 model in Bali blue
Tue Jan 17 2012 12:52pm |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 |
My next door neighbour actually made a point of speaking to m the other day about the RRS. he wanted to tell me that on several occasions when he had been out in the front garden he had heard my car making noises. Not just the same one but several different ones.
Wed Jan 18 2012 9:47am |
