![]() | Home > General > Detatchable Tow Bar |
beefbops Member Since: 04 Jan 2012 Location: Prestwick Posts: 46 ![]() ![]() ![]() |
Hey all, I've looked in my boot and the tow bar ain't there. My question is, do all RRS come with detachable tow bars and electrics ? Is it just a case of me buying a tow bar ?
Cheers Nik |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9028 ![]() ![]() ![]() |
You might have the electrics if the car is second hand. Mine had the electrics but no tow bar. Looked at the tow bar fitting behind the rear bumper and it had definitely been used; I guess the previous owner took it with him. Which was annoying but then I should have checked before I paid the dealer for the car! 2012 SDV6 - it's missing a couple of cylinders
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
Mine was the same, Tow Ball missing but luckily the dealer has taken the spec from the system and listed the car for sale with Tow Pack.... so they kindly supplied me with a nice new removable tow ball.
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
Unless the car was factory fitted with the tow pack, the dealer wouldn't necessarily be liable , I had mine fitted aftermarket , and I will take the towbar with me when it gets traded in!! Some cars left the factory with electrics fitted anyway, they build a car to a spec then change it at last minute - it's not worth the hassle to take it back off! Cheers Dave MY10 TDV6 SE (debadged ![]() Gone: a comprehensive list of imprezas and a Merc ML AMG |
@codfather: true, but it's always worth checking when buying as x5pea showed. Assuming something's fitted can be expensive later when you discover it isn't... 2012 SDV6 - it's missing a couple of cylinders
Yes , I know, some dealers will hold back the hitch until on a used car until asked for it, some people won't touch a car that has been used for towing. If they don ask then I'm sure they end up on eBay to fund the Christmas night out!! ![]() If towpack is stated on the spec, then the car should be sold as such, bit like going to pick up your car and finding they only put 3 wheels on it!! Cheers Dave MY10 TDV6 SE (debadged ![]() Gone: a comprehensive list of imprezas and a Merc ML AMG |
LeighG Member Since: 25 Aug 2011 Location: Southampton Posts: 55 ![]() ![]() ![]() |
I bought the hitch and electrics off ebay and fitted it myself. Took about 30 minutes to fit, it is just a plug and play wiring harness. The fiddly bit is feeding the cable through the grommet. LR Defender 90 - gone
