Home > General > Wheel wobble when braking after pads replaced front and rear
wokkaman
United Kingdom 2013 Range Rover Sport Supercharged HSE Zermatt Silver
My sc went in for 24k service and need pads replacing (been having fun), but over the last 1k Wheel wobble when braking, but also more noticeable after longer drives? Any ideas?? Anyone with same problem?? GONE** RRS 3.0SC Silver fully loaded Smile - 2020 110 loving it
BMW R1200GSA Rallye
GONE** Fiesta ST2 - Mrs Wokka's - AMG35 now
GONE**BMW K1600GTLE Matt Blue
GONE**Disco 4 2014 Firenze Red
GONE**Evoque SD4 Dynamic Coupe
GONE**RRS 5.0 SC
GONE**RRS HSE TDV8
GONE**RRS HSE TDV8 (The Crap one)
GONE**FL Facelift
GONE**FL 1
GONE**D1
GONE**BMW R1200GS Adventure
GONE: Kawasaki ZX10R
GONE: Focus ST2
** Chinook CH47 - 2 x T55 engines 3,750 hp each!! 183mph, 2xM134 Miniguns, 1xM60
Post #327527 Tue Jan 10 2012 12:03am
felstmiester
United Kingdom 2005 Range Rover Sport TDV6 HSE Santorini Black
Warped discs. They was more than likely like it before but the fact u've had new pads fitted shows off the problem. I had the exact same problem.
Post #327530 Tue Jan 10 2012 6:36am
^^^ Agree with Felstmiester, had exactly the same on my BM a few years ago, seemed the changing of the pads highlighted the warping more.
They may be able to skim them back into line if they're not that bad, else it'll be a new set. ON THE WAY: BMW F21 M140i
Post #327533 Tue Jan 10 2012 8:09am
Supacat
are they the same brand and have you bedded them in?
Post #327534 Tue Jan 10 2012 8:30am
wokkaman
I guess so as they were fitted by dealer (boy is that expensive)... Done just over a 1k miles since, as for warped discs Shocked It's a Supercharged, therefore it's brakes should cope with anything... No? And should of been spotted by dealer during change and service?? GONE** RRS 3.0SC Silver fully loaded Smile - 2020 110 loving it
BMW R1200GSA Rallye
GONE**RRS 5.0 SC
GONE**RRS HSE TDV8
GONE**FL Facelift
GONE**FL 1
GONE**D1
GONE: Focus ST2
Post #327552 Tue Jan 10 2012 10:08am
Don't bet anything you can't afford to lose on that statement Rolling with laughter
Although the discs are on a S/C they could still warp unfortunately Sad ON THE WAY: BMW F21 M140i
Post #327556 Tue Jan 10 2012 10:22am
XRM
Just had my S/C in for a 24,000 mile service (@10,500miles on the clock) the Mech. said there was a bit of brake flutter not that i noticed or reported but they changed the Disc's under warranty anyway. 2015 SD V6 A/B
Post #327589 Tue Jan 10 2012 4:27pm
Bodsy
Site Sponsor
Re: Wheel wobble when braking after pads replaced front and
Wokkaman, take the wheels off, check for any crud between the wheel & disk & then put them back on, tightening the nuts up in Opposite order. Starting at number 1, so go 1, 3, 5, 2, 4
Torque setting should be 140nm.
Sometimes you find if garages just tighten them in 1,2,3,4,5 order, the wheel doesn't sit quite straight and this can cause partyly your problem.
Regrding the disks 'warping' (taken from someone else who knows these things, not me) It is rare for a normal disk to warp, but if the brake dsks get hot, the brake pad can soemtimes stick to the disk, causing the same effect by the resiudue that is left on the disk. Alternatively, it can also be the disk getting very hot and cooling which changes the hardened properties of the disk and causes the juddering/wobble.
HTH
Ian Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #327847 Thu Jan 12 2012 3:34pm
felstmiester
Any disc can warp. It just depends on driving style, wieght of motor, and another factor is a disc is more likely to warp if braking is hard and aggressive when it's cold. I had a 12 pot big break kit on an m5 I used to own, 5 laps of hard driving round brands hatch and they was warped to the extent that you could hardly hold the steering wheel under breaking. The m5 is a heavy car just as the rrs is heavy, they take a lot of slowing down hence more likely to warp discs.
Post #327856 Thu Jan 12 2012 4:47pm
Supacat
Bodsy's on the money for me. Don't throw perfectly serviceable discs without checking pad transfer 1st. If you have high performance brakes and pads then you should bed them in when new not just use them.
felstmiester - there's a world of difference between road driving and a trackday. In my experience, you get nowhere near the limits on the road as you do on a circuit doing the same corners repeatedly from triple digit speeds every 2 mins or so...
Post #327913 Thu Jan 12 2012 11:06pm
felstmiester
Supercat. Yes totally agree with you. I was just stating that any disc can warp, even if it's designed for the job. The break kit I had on the M5 was specifically made for that car by tarox. The break kit alone is £6000 + for the front rotors rear rotors and calipers, they're huge!! They went through the proper bedding in process just like tarox advised but still failed when doing the job they was built to do.
Post #327918 Fri Jan 13 2012 6:02am
That was a waste of 6k then Confused Big Cry
Post #327922 Fri Jan 13 2012 8:15am
Supacat
felstmiester - good on you for tracking an M5 Thumbs Up
A 12 pot kit is huge!
Post #327927 Fri Jan 13 2012 8:39am
In stark contrast to Felstmiester, disks on my mothers VW Polo warped @ 20k miles, believe me, that car barely goes above 40 mph Laughing ON THE WAY: BMW F21 M140i
Post #327930 Fri Jan 13 2012 8:57am
In all fairness to your mother, the older end do drive with their foot on the brake at all times Laughing
Post #327935 Fri Jan 13 2012 9:10am
