Home > General > Wheel wobble when braking after pads replaced front and rear |
wokkaman Member Since: 08 Nov 2006 Location: GU34 Posts: 761 |
My sc went in for 24k service and need pads replacing (been having fun), but over the last 1k Wheel wobble when braking, but also more noticeable after longer drives? Any ideas?? Anyone with same problem?? GONE** RRS 3.0SC Silver fully loaded - 2020 110 loving it
Tue Jan 10 2012 12:03am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
^^^ Agree with Felstmiester, had exactly the same on my BM a few years ago, seemed the changing of the pads highlighted the warping more.
Tue Jan 10 2012 8:09am |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 |
are they the same brand and have you bedded them in? |
Tue Jan 10 2012 8:30am |
I guess so as they were fitted by dealer (boy is that expensive)... Done just over a 1k miles since, as for warped discs It's a Supercharged, therefore it's brakes should cope with anything... No? And should of been spotted by dealer during change and service?? GONE** RRS 3.0SC Silver fully loaded - 2020 110 loving it BMW R1200GSA Rallye GONE** Fiesta ST2 - Mrs Wokka's - AMG35 now GONE**BMW K1600GTLE Matt Blue GONE**Disco 4 2014 Firenze Red GONE**Evoque SD4 Dynamic Coupe GONE**RRS 5.0 SC GONE**RRS HSE TDV8 GONE**RRS HSE TDV8 (The Crap one) GONE**FL Facelift GONE**FL 1 GONE**D1 GONE**BMW R1200GS Adventure GONE: Kawasaki ZX10R GONE: Focus ST2 ** Chinook CH47 - 2 x T55 engines 3,750 hp each!! 183mph, 2xM134 Miniguns, 1xM60 |
Tue Jan 10 2012 10:08am |
Don't bet anything you can't afford to lose on that statement Although the discs are on a S/C they could still warp unfortunately ON THE WAY: BMW F21 M140i MERCEDES GL350 - Metallic Navy Blue w/Grey interior GOING: BMW F31 335D MSport+ xDrive Touring GONE: Land Rover Discovery 4 HSE - Stornaway Grey w/Black Interior (wish we'd kept it ) GONE: BMW F10 520D MSport - Carbon Black GONE:MY12 RRS SDV6 HSE Sumatra/Ivory/Grand Black Privacy glass |
Tue Jan 10 2012 10:22am |
XRM Member Since: 30 Jan 2007 Location: Worldwide Posts: 26 |
Just had my S/C in for a 24,000 mile service (@10,500miles on the clock) the Mech. said there was a bit of brake flutter not that i noticed or reported but they changed the Disc's under warranty anyway. 2015 SD V6 A/B |
Tue Jan 10 2012 4:27pm |
Wokkaman, take the wheels off, check for any crud between the wheel & disk & then put them back on, tightening the nuts up in Opposite order. Starting at number 1, so go 1, 3, 5, 2, 4 Torque setting should be 140nm. Sometimes you find if garages just tighten them in 1,2,3,4,5 order, the wheel doesn't sit quite straight and this can cause partyly your problem. Regrding the disks 'warping' (taken from someone else who knows these things, not me) It is rare for a normal disk to warp, but if the brake dsks get hot, the brake pad can soemtimes stick to the disk, causing the same effect by the resiudue that is left on the disk. Alternatively, it can also be the disk getting very hot and cooling which changes the hardened properties of the disk and causes the juddering/wobble. HTH Ian Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
Thu Jan 12 2012 3:34pm |
felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203 |
Any disc can warp. It just depends on driving style, wieght of motor, and another factor is a disc is more likely to warp if braking is hard and aggressive when it's cold. I had a 12 pot big break kit on an m5 I used to own, 5 laps of hard driving round brands hatch and they was warped to the extent that you could hardly hold the steering wheel under breaking. The m5 is a heavy car just as the rrs is heavy, they take a lot of slowing down hence more likely to warp discs. |
Thu Jan 12 2012 4:47pm |
Bodsy's on the money for me. Don't throw perfectly serviceable discs without checking pad transfer 1st. If you have high performance brakes and pads then you should bed them in when new not just use them.
Thu Jan 12 2012 11:06pm |
Supercat. Yes totally agree with you. I was just stating that any disc can warp, even if it's designed for the job. The break kit I had on the M5 was specifically made for that car by tarox. The break kit alone is £6000 + for the front rotors rear rotors and calipers, they're huge!! They went through the proper bedding in process just like tarox advised but still failed when doing the job they was built to do. |
Fri Jan 13 2012 6:02am |
That was a waste of 6k then |
Fri Jan 13 2012 8:15am |
felstmiester - good on you for tracking an M5
Fri Jan 13 2012 8:39am |
In stark contrast to Felstmiester, disks on my mothers VW Polo warped @ 20k miles, believe me, that car barely goes above 40 mph ON THE WAY: BMW F21 M140i
Fri Jan 13 2012 8:57am |
In all fairness to your mother, the older end do drive with their foot on the brake at all times |
Fri Jan 13 2012 9:10am |
