Home > General > SatNav volume
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
SatNav volume
Tried looking online but could not find anything useful, although I do remember a thread similar to this one a year or go or so.
Anyway, sometimes I listen the music a bit loud (not too loud, say 7 out of 10) and have SatNav turned on at the same time, SatNav voice commands comes in suddenly SO loud Big Cry , it nearly makes my ears bleed... Is there a way to reduce SatNav volume?
Thank you in advance Vadim A.
Post #327073 Fri Jan 06 2012 1:16am
andman
Andorra 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
I don't know what model year you have.... but on my 2012..... when the satnav is actually giving the commands turn the volume knob down and she will stop screaming..... all the way down to a whisper...
This also works for other audible sounds in the car including the park distance control......
Great logical system... in my other car you need a programming degree to do the same thing
Post #327074 Fri Jan 06 2012 6:55am
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
i find the best setting for any female voice giving instructions whilst i am driving is OFF Whistle Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #327104 Fri Jan 06 2012 12:23pm
scrumps
Re: SatNav volume
Try looking at Page 283 of the Owners Handbook.
If you hold down the "tone" button (muical note) on the dash, the volume menu comes up allowing you to set Nav, Phone etc volumes individually.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #327113 Fri Jan 06 2012 1:53pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
u just adjust the volume when its talking via the same controls for the stereo.
The setting is based on the volume of the stereo + or - the nav volume setting.
Post #327120 Fri Jan 06 2012 3:25pm
Mr H
England 2009 Range Rover Sport TDV8 HSE Santorini Black
But that doesn't keep the volume at that level, the next time the sat nav comes in on mine she's back to the same previous loud level Question Have i got the busted controller?!?!!?
2009 RRS TDV8
Santorini Black
Ivory / Anigre
Privacy
DVD & TV
Side Steps
Post #327134 Fri Jan 06 2012 7:55pm
andman
2012..... she stays where she's told!!!
Post #327136 Fri Jan 06 2012 8:04pm
Mr H
Someone help us for 09 and earlier tho pleeeeeeeeease Big Cry Have i got the busted controller?!?!!?
2009 RRS TDV8
Santorini Black
Ivory / Anigre
Privacy
DVD & TV
Side Steps
Post #327137 Fri Jan 06 2012 8:06pm
Vadim
Exactly! I have the same problem and i have MY10 model. Vadim A.
Post #327178 Sat Jan 07 2012 2:28am
Roland
Switzerland
same here, and seemingly there's nothing we can do Big Cry Big Cry
It must be a software issue or something and only affects MY10 and MY11 cars SOMETIMES YOU'RE THE BUG AND SOMETIMES YOU'RE THE WINDSHIELD
2010 TDV8 Ultimate Edition, zermatt-ebony-grand lacquer, and all the goodies, plus Superchips Bluefin ECU performance upgrade, Gibson Performance exhaust tips
gone after only 7 months: MY10 TDV63.0 HSE, zermatt-ebony-anigree, Dynamic Response, Rear diff-lock, flappy paddles, premium leather, Sunroof, PTI, privacy glass, S/C design 5 Spoke Diamond Turned alloys
Post #327180 Sat Jan 07 2012 7:24am
scrumps
Vadim,
Mine is a MY10 TDV8 and I followed the instructions in the handbook when the phone nearly blew me out of the car on the way home during the delivery trip.
Here's the excerpt from the MY10 manual section "Audio level setting" - it works on my car !!!!:-
Audio level settings VOLUME ADJUSTMENT
Sustained exposure to high sound levels can
damage your hearing.
To access the volume set up menu,
press and hold the Tone hard key
until the volume set up menu is displayed. The
soft keys to the left, allow you to choose a
setting to adjust (AVC, INFO, NAV, PHONE and
VOICE). The boxes to the right of the soft keys
show the values currently set for each option.
The bar graph and the +/� soft keys are used to
change the settings and show the changes.
Note: If no change is made within ten seconds,
the volume set up menu will disappear.
Automatic Volume Control (AVC)
Automatic Volume Control adjusts the volume
level as the vehicle speed increases. This
compensates for the increase in noise at
increased speeds.
From the volume set up menu, touch the AVC
soft key to display the settings for AVC.
The bar graph represents the amount by which
the volume level may increase. If the smallest
bar is selected, the AVC function will be turned
off. In this state the volume will not increase
with vehicle speed. The remaining bars (from 1
to 9) will increase the volume level up to the
maximum level selected.
To increase the level of volume change, press
the + soft key. Each press will select the next
bar to the right, up to the maximum (9).
To decrease the level of volume change, press
the � soft key. Each press will select the next
bar to the left, down to the minimum (1). A
subsequent press of the � soft key will switch
AVC off.
Information announcements
Press the INFO soft key from the volume set up
menu, to adjust the volume level for radio
announcements, such as news broadcasts and
traffic announcements on RDS.
To increase the volume level, press the + soft
key. Each press will select the next bar to the
To decrease the volume level, press the � soft
Navigation guidance
Press the NAV soft key from the volume set up
menu, to adjust the volume level for navigation
guidance messages.
Telephone volume
Press the PHONE soft key from the volume set
up menu, to adjust the volume level for the
telephone.
right, up to the maximum (25).
left, down to the minimum (5).
According to the Topix manual for a 2009 model car - Pages 276-278 there is the same facility with "pre-facelift" cars but it's accessed slightly differently.
Come on chaps - RTFB Very Happy
Post #327188 Sat Jan 07 2012 10:22am
alanad
Scotland 2013 Range Rover Sport SDV6 HSE Bonatti Grey
I posted a thread about this about a year ago. Doing what scrumps suggests only changes the volume in relation to the volume you are listening to on the radio. You cannot decrease the volume lower than what the radio or whatever you are listening to is set at - you can only set it to be at or louder than what you are listening to. I do RTFM.
In my jag you used to be able to fully set the Nav volume indepentently of anything else you are listening to so it always came in at an acceptable volume. It's strange given the two systems are very similar. 3.0 SDV6 HSE Dynamic, Corris Grey with contrast Santorini Black Panoramic Roof, lunar interior, privacy glass, upgraded Meridian system, cooled 18 way front seats, heated steering wheel, adaptive xenons, large screen wash bottle.
Gone: 3.0 TDV6 HSE, Santorini Black, Ivory/Lunar interior, grand black lacquer finish, HK Logic 7.1 Surround, Privacy Glass, Adaptive Xenons, heated steering wheel.
Gone: Jaguar XF Luxury, Pearl Grey, Dove Interior
Post #327198 Sat Jan 07 2012 2:05pm
scrumps
Alanad - I'm glad someone else RTFM/B's.
I assumed from the original query of "loud radio = VERY loud NAV" that Vadim just wanted to reduce the "VERY" to "slightly" - hence my suggestion.
Post #327203 Sat Jan 07 2012 3:08pm
Vadim
@Aland, thank you for the comments. You got it right.
@scrumps - sorry for the misleading quiery Sad
It seems like what I am asking for cannot be done Censored The only way out is to switch off the voice commands... Vadim A.
Post #327211 Sat Jan 07 2012 4:30pm
Mr H
Looks like another candidate for my "what were they thinking" post Exclamation Have i got the busted controller?!?!!?
2009 RRS TDV8
Santorini Black
Ivory / Anigre
Privacy
DVD & TV
Side Steps
Post #327219 Sat Jan 07 2012 8:39pm
