Home > General > Top Up |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 |
I checked with the service dept what oil they put in, and it was shell helix, so have been putting that in ever since!
Fri Dec 30 2011 6:16pm |
iknight167 Member Since: 11 Sep 2009 Location: STAFFS Posts: 11 |
Many thanks. |
Fri Dec 30 2011 7:00pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Is that common for it to lose/usethat much oil in such a short space of time/mileage? ON THE WAY: BMW F21 M140i
Fri Dec 30 2011 10:31pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Good question. Oil half way up the stick would be about right. I'd monitor it on a weekly basis and see if it drops at all - which it really shouldn't on a new car.
Fri Dec 30 2011 11:43pm |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 |
That Castrol Oil is so hard to find that its almost unbelievable! Why? SVR 2018 in Santorini Black. |
Sat Dec 31 2011 3:36pm |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 |
Was the oil still hot from a run or cold? Check after 15 to 20 minutes after a run not say next morning. Synthetic oils quite a bit so checking level with a cold engine could result in overfilling which is worse than being a bit low.
Sat Dec 31 2011 5:41pm |
Later mdl RRS , oil can only be checked about 15mins after use. SVR 2018 in Santorini Black. |
Sat Dec 31 2011 6:49pm |
Good point TDV8HST, I'd forgotten about that. |
Sat Dec 31 2011 11:41pm |
