![]() | Home > Faults & Fixes > Engine management light on |
Mike waldie Member Since: 09 Nov 2011 Location: Cronton Posts: 147 ![]() ![]() ![]() |
It's the yellow light that's on, not flashing but still peeing me off..... |
NickM Member Since: 15 Feb 2008 Location: London Posts: 2995 ![]() ![]() |
EGR valves maybe......leave overnight and see tomorrow....... |
And if still on Tomoz start to worry?????? |
How old is the car? EGR valves are very common....sometimes you won't even notice any loss in power.... |
2008 and it's on just over 56k now..... |
Call breakdown mate for some peace of mind...they should be able to tell you...... |
You mean I should ring AA and get them out??? |
No I mean call Ghostbusters.......
Haha it's the drink, unless there's something more than the 3 years on the car then I don't have any lr cover |
mike21 Member Since: 07 Feb 2011 Location: Essex Posts: 297 ![]() ![]() |
Same happened to me a couple of weeks ago, was the EGR valve, replaced under warranty otherwise a �420 fix. The dealer did say the other one would probably go in a few weeks |
firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461 ![]() ![]() ![]() |
could be anything, get it on a diags machine, either ebay one or get slapped at the dealers for it. |
Tried it again before, turned the car on and off 3 mor times and the light has gone off!!!! Fingers crossed that's it but think it may come back. Has this happened to people before????? |
mark hamster Member Since: 26 Nov 2011 Location: nottingham Posts: 116 ![]() ![]() ![]() |
if it egr valve like mine was the aa on both times took less than 5 mins to find fault.! the best way was to feel the mesh pipes under engine cover,one of mine was cold and one hot,so thats how he found it.!! top tip,i had aa warranty repair cover,aa man talked me into it when joined aa.! glad he did as they picked up bill off �400 minus �35 excess.!! thats for just one,the other went soon to and they paid up again.! not bad as i only been with them a few months and only paid them about �25. result |
Mine was on and fault code was P0490 - EGRs. I got geared up to start replacing and disconnected the passenger side EGR electrical connector while having a look how tight things are - reconnected the connector and faulkts cleared - came back twice but has now gone after me playing with contacts in the connector - fault was just a contact not connecting.
