Home > Maintenance & Modifications > Timed Climate
mse
Timed Climate
I went to enable time climate today - but for the life of me couldnt find the option, although we werent sure if there was an update to apply.
Anyone know which module its in, i have access to 2 land rover diagnostic tools. Mike
2014 Facelift Discovery
Post #325202 Wed Dec 14 2011 11:05pm
Jimmy_75000
it isnt standard equipment...u sure you have it? Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #325224 Thu Dec 15 2011 9:04am
mse
It is from 2010 and mines a 2011, but im sure...you have to enable the option on the screen as the kit uses the fuel burner and the "extra" bit of kit you need is the remote and its associated module if you want to turn it on without a schedule - i dont.
But i couldnt find the option in the diagnostic tools, found many other things...just not that Mike
Post #325230 Thu Dec 15 2011 10:32am
Jimmy_75000
Mine is a 2010 and I don't have it... Range Rover Vogue ‘17 TDV6
Post #325235 Thu Dec 15 2011 11:06am
mse
2 things - you might not have the option, but you have the capability, the option is what you have to enable via some form of LR diagnostic equipment - do you have the park fuel burner (front left of the engine) if not, the second point might be yours is too early in 2010.
Timed climate is only turning the fuel burner on to heat up the range rover before you start it, add in the remote module you can turn it on say from your house before you go out if you notice it is cold.
The fuel burner will run (if you have it fitted) to speed the heating process of the engine and car when cold (below 5 or 7 degrees i cant remember) its the remote start option that im enabling. We had it running by enabling it while the car was off under the diagnostic side, but i couldnt find the option to display the feature on the infotainment screen normally
Lots of post on here and the D3/4 forum - lots, but many people dont have the diagnostic equipment themselves so go to someone like Wiggs or BAS to have them do it...I have access to the equipment so in theory can do it myself if i knew where to look Mike
Post #325237 Thu Dec 15 2011 11:11am
Tell me more, this sounds very Cool ......what am I looking for in the engine area to see if the burner is fitted ?
Then, how do i go about getting it set up ?
TIA ON THE WAY: BMW F21 M140i
Post #325239 Thu Dec 15 2011 11:15am
mse
i thought everyone knew about this.
Right - this is the kit that heats the car
Then you need to get it enabled to control it:
(Borrowed from BAS D4.com)
and those i referenced above can do that if you dont have the tools to do it - do a search to find out more! a few hundred pounds will see you part of the way Mike
Post #325243 Thu Dec 15 2011 12:15pm
Thanks MSE, I'll take a look under the bonnet later on and do some searches Thumbs Up ON THE WAY: BMW F21 M140i
Post #325246 Thu Dec 15 2011 12:59pm
wiggs
MSE ....i dont believe its possible with the LR IDS tool Sad Bluetooth Exchange www.bluetoothexchange.co.uk
Post #327485 Mon Jan 09 2012 9:00pm
mse
Thanks i was trying with Autologic aswell, do you have any experience with that one? Mike
Post #327506 Mon Jan 09 2012 10:40pm
wiggs
No sorry ... But I do believe that it can enable timed climate ( well on a disco 4 anyway ) Bluetooth Exchange www.bluetoothexchange.co.uk
Post #327508 Mon Jan 09 2012 10:42pm
mse
not to worry - thanks anyway...we havent done an update, so thought it might have required that, but as i had the laptop with the software to update it on to fix...i couldnt. Mike
Post #327526 Tue Jan 10 2012 12:50am
Krx84
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Anybody
Is anybody in the manchester area activating the menus? RRSport - 2010
Post #327761 Wed Jan 11 2012 9:57pm
JUCOTT01
Just done mine today with an AUTOLOGIC 15mins later sorted Thumbs Up Thumbs Up
Bring on the cold weather Mr. Green
Any body in the glasgow area needing it activated just send a PM RRS MY11 BALI BLUE OVERFINCH
Post #327764 Wed Jan 11 2012 10:04pm
mse
Where is the option in autologic if you dont mind...have you the latest updates from them, we hadnt. Mike
Post #327797 Thu Jan 12 2012 1:05am
