Home > Technical > side skirt Rubber Moulding removal
robbo5522
Scotland 2007 Range Rover Sport TDV6 HSE Santorini Black
Hi, Very Happy
New RRS and just bought a 55 plate RR, Anyway like to say its FANTASATIC site and i hope someone can help !!,
Would like to remove the side skirt moulding on the RRS, think a few clips are broken and need to be replaced, But not to sure if it pull off or lift to a position then pull it off ????????,
sure hope someone can help
Robbo5522 Very Happy
Post #227525 Mon Jun 08 2009 8:22am
jammy
United Kingdom 2005 Range Rover Sport Supercharged Zambezi Silver
Hi Robbo5522
If you are talking about the plastic mouldings located at the bottom of the doors, they just pull off. They are held on by plastc clips which are in two halves. The trouble is some of the clips are likely to break so you will have to get some replacements from your local dealer.
The small moulding bottom of the front wing has a couple of clips and one screw on the inner wheel arch.
The curved moulding over the rear wheel arch has a number of clips and if I remember rightly has one screw.
Mouldings are quite difficult to push back onto the clips without breaking more clips - trial and error I'm afraid.
Buy more clips than you need...!
FYI I removed all the mouldings for color coding plus fitting of sidesteps etc.
Post #228361 Tue Jun 16 2009 3:56pm
robbo5522
Hi Jammy,
Appreciated thanks for your help, thought would be a bit of a nightmare to remove without breaking clips, Big Cry anyway thanks for your time and help.
have a nice day Very Happy
Post #228413 Wed Jun 17 2009 8:29am
Tim in Scotland
I think (not sure as he had so many "events" with his TDv6 Mr. Green ) that VA posted about this last year. IIRC there are two types of clip - white and yellow. Anyway if you try the search function I'm sure that you will find a post in the archives about refitting the side skirts- might be worth searching using "door trim" as the key words 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #228415 Wed Jun 17 2009 8:50am
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
I bought a BIG bag of them as the do break when you bottom out the car, as in this clip http://www.youtube.com/watch?v=mtQ53_W01Rk p.s. I wasn't driving Big Cry Sons of dogs come hither and get flesh
Clan Cameron
Post #228419 Wed Jun 17 2009 8:58am
Alicatt
Here is the offending clip
Clan Cameron
Post #228420 Wed Jun 17 2009 9:24am
jammy
Yep those are the clips.
Notice the clips are in two halves one white and the other yellow.
During factory assembly the complete clips white and yellow are inserted into a retaining slot in the mouldings. The moulding is offered up to the car body and the yellow portion squeezes through a hole in the car body.
When removing the mouldings either the white and yellow halves separate without breaking which is good Very Happy
OR the white clips fail in moulding and have to be replaced Big Cry
The trouble is even if the white clip doesn't break you then have the problem of trying to make the two halves clip together again when offering the moulding back to the car body.
Ideally what you need to do is to remove the yellow half from the car body and push it back onto the white half of the clip on the moulding. Unfortunately the yellow half pushes into the body easily but is very difficult to remove without breaking.
Anyone got any other ideas ?
Has anyone broken the yellow half on purpose and just pushed it in to the body for it to bounce around forever Whistle
Post #228442 Wed Jun 17 2009 11:53am
eshber
Really having some trouble here. The bottom row of the moulding isn't clipping back onto the yellow clips that are in the door. I tried to remove the yellow clips but this is impossible as it seems once these clips are in the only way to get them out is by breaking them - even still, the back half of the yellow clip would fall into the doorframe.
Is there a special technique to this?
Help!! I went from a Mini Cooper to a:
>> Range Rover Sport (HSE)
>> Midnight Blue
>> '06
>> Hawke Grill, Engine Tuning, Exhaust System
>> Sitting in 20s (need to upgrade to 22s - let me know if you have any for sale)
>> Rear DVD screens
>> Full Beige Leather Interior
Talk about the extra room! Jheez!!
Post #323645 Fri Dec 02 2011 11:20am
