Home > Technical > Snow chains, 2 or 4 wheels. What's the difference?.... |
oxford-boy Member Since: 10 Nov 2011 Location: Oxford Posts: 148 |
Anyone enlighten me as to who is correct on the snow chain debate?
Tue Nov 29 2011 1:53am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
I too am confused
Tue Nov 29 2011 10:25am |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
All 4 I would say, but I'm no expert |
Tue Nov 29 2011 10:35am |
Thanks guys. I think all four. The car weighs nigh on two and half tons and if the rear end were to go on an icy snow covered road the fronts would do little more than act as pivot. The rear wheels are the park brake too.
Tue Nov 29 2011 11:49am |
you need to make the choice of being able to stop or being able to steer
Tue Nov 29 2011 12:59pm |
Exactly! I can't see how LR can say DO NOT without some justification.
Tue Nov 29 2011 1:30pm |
maddogsetc Member Since: 03 Sep 2011 Location: Hampshire Posts: 51 |
Not sure if this helps but there are threads on this on disco3.co.uk - ISTR that the chains can foul the chassis / suspension members on the rear unless you use spacers. Presume the same would be true for RRS. |
Tue Nov 29 2011 1:36pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Agree with statement that LR have to justify if they say fronts only. The brake balance is very much biased toward the back wheels so it would seem logical that if you didn't use the chains etc on the rears then you'd
Tue Nov 29 2011 1:44pm |
Well, if maddogsetc information from disco3.co.uk is correct then what we have is a situation that they just won't fit not that they aren't required. That seems rather worrying....
Tue Nov 29 2011 2:11pm |
Just to be clear, these are what I use when I say snow chains...
Tue Nov 29 2011 2:21pm |
ive used them in thick snow on all four wheels. Mind you, did have spacers on (D3), but other than that, there's no reason why you wouldn;'t want them on all four wheels.
Tue Nov 29 2011 3:23pm |
Thank you.
Tue Nov 29 2011 3:33pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8983 |
It's still confusing:
Tue Nov 29 2011 4:53pm |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 |
Could it be because Landrover's Traction thingies are sold in pairs so stating they must be fitted to the front is to avoid anyone fitting a pair onto the rear wheels only. Fitting to the front wheels does allow traction, steering and braking control while on the rear the important steering control becomes nonexistent.
Tue Nov 29 2011 7:16pm |
